Hows the Hay Season Going
   / Hows the Hay Season Going #1
Hoosier Hay Man
Platinum Member
Indiana
Kioti DK45S Cab, Quicktach FEL
First cutting finished in Indiana. Dry and hot this hay season in the Hoosier State. The last 2 seasons were wet. Finished first cutting in July last season. Yield was off by 40% this year due to the dry weather and late freeze after 80° temps in March. I did a 17 acre that yielded 78 rounds which was real good for this year.
   / Hows the Hay Season Going #2
First cutting finished in Indiana. Dry and hot this hay season in the Hoosier State. The last 2 seasons were wet. Finished first cutting in July last season. Yield was off by 40% this year due to the dry weather and late freeze after 80ー temps in March. I did a 17 acre that yielded 78 rounds which was real good for this year.
Glad to see some hay being made:thumbsup: Maybe in a couple weeks I can get a few made,and I mean a few...
   / Hows the Hay Season Going #3
Got my first cutting in the barn 3 weeks ago yesterday. Red Clover, and Alfalfa was in full bloom, and Rye Grass just out of the sheath.
Wish I could have weather to make it that early every year. Certainly looks good for 2nd and 3rd cutting..!
Sure could use a shot of rain though... Looks like a good chance Tuesday, although with two strong front colliding, it will probably be a Toad strangler...
   / Hows the Hay Season Going #4
Great to see ... been an early spring with alot of Rye grass hay put up here. It had alot of clover and some bermuda along with the rye and selling as fast as we bale. Rain is the main topic now. If we don't get some there will not be a second cutting .... this week we have a chance and I'm holding a field in hopes of rain ... if it does I can let it grow some more ... if it doesn't rain, I'll cut, rake and bale it before it burns up.
   / Hows the Hay Season Going #5
One more small field and we'll be done with our first cutting here in SE KY. I don't ever remember being done before June 1. Usually everyone is starting around memorial day. Yields are GREAT where I've used chicken litter, off about 1/4th where noone has fertilized.
Hoosier Hay Man how big are those rounds on the 17 acres? I got 18 4x5s from a little over 4 acres (I figured it at 4.25 for 4.23 bales per acre) and I had never done that good. It's amazing the difference in yield when someone takes care of the soil. Problem here is we lease a lot and as soon as you get it right someone else gets it. Then they don't fertilize it and it goes right back to nothing in a few years.
   / Hows the Hay Season Going #6
Are prices up, down or about the same as last year?
I hadn't bought hay in years and was in the local feed store the other day and noticed 2x2x4 bales of grass hay at $24 and alfalfa at $21
Most of their customers have one or two horses so they buy no more then a few bales at a time...
   / Hows the Hay Season Going #7
In my area they are higher than before the drought, not as high as during the drought ... but if it don't rain they will go up.
The rounds are 5x4. It was the best field. I baled 1200 small squares off of 20 acres. I put on 200lbs of potash to the acre after first cut. It is over $600 a ton
this year. 6 years ago it was around $250 a ton. I am defiantly putting on all of the manure I can this fall. I will soil test late summer. Also want to lime before winter this year.
   / Hows the Hay Season Going #9
We had some strange weather. Dry hot march and cold wet April and into May. Many around here are still trying to get spring planting done. This is latest a friend of mine has planted his corn in the 20 years he has been farming by a couple of weeks.
Normally we start 1st cutiing about now, it will be a few more days for us. A guy up the road chops 100% and is normally done with his 1st by now. He has started but isn't done.
   / Hows the Hay Season Going #10
Got my first cutting down and in the barn. Got rained on a little but it needed cut bad, so now i'm looking forward to my 2nd cutting and helping a neighbor with his first cutting.
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2016 Mack CXU613 T/A Wet Kit Day Cab Truck Tractor (A50323)
2016 Mack CXU613...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2020 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2020 Ram 1500 4x4...
John Deere 2210 Compact Tractor (RUNS) (A50774)
John Deere 2210...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
