Howdy Neighbor
/ Howdy Neighbor #1
Goose67
I have a Kubota BX2360 w/ front loader, and 4 foot Howes shredder.
Need to know if a armstrong 5 ft. box blade is too big for this tractor and need a 4 ft. instead?
/ Howdy Neighbor #2
Hi,
I moved your thread into the Kubota Owning/Operating -- more of our Kubota experts will see it here and be able to help you out!
Thanks for joining TBN!
/ Howdy Neighbor #3
Welcome to TBN. You'll be able to do some light duty work with a 5ft box behind a BX, but it will be limited because you can fill it with more material than the tractor can effectively pull. You would likely get more real work done with a 4ft because you can actually dig, fill and pull the attachment with a BX-size machine.
If you already have the 5ft box, go ahead and try it, but if you're trying to decide what to buy, definitely go for a 4ft size. The 4 ft size is also a perfect rear ballast for loader work on a BX, and, since it doesn't jut out beyond the width of the tractor so much, it is not as likely to snag something.
/ Howdy Neighbor #4
I would get a 4 footer. It may be a little smaller but you can fill the box to full capacity and pull it rather than half capacity at a 5 footer.
/ Howdy Neighbor #5
I had a five footer I had been using on my NAA and used it on mine for a while, but didn't like it and got a four foot. I like it a lot better.
/ Howdy Neighbor #6
I have a BX 2350 and have used a five foot box blade with my tractor. It will do fine for smoothing the driveway and light work, but if you put the rippers down and really try to move a lot of dirt, it will stop it in its tracks. If I were buying a new one, I would definitely get a four-foot blade.
