Howdo I check the injectors and fuel pump on Perkins 903.27?
   / Howdo I check the injectors and fuel pump on Perkins 903.27? #1
def38
Platinum Member
woods and mountains of Alabama
M-F 231S
My M-F 231S is equipped with a Perkins 3 cylinder diesel engine which has run flawlessly since I bought the tractor used. I would like to check the injectors and fuel pump to make sure all is well. What do I need to do?
   / Howdo I check the injectors and fuel pump on Perkins 903.27? #2
Remove them & take them to a qualified shop for testing.
OK. Once I have them back, how do I insure no air is in the system? If the pump needs work, can I send it to you pumpguy?
   / Howdo I check the injectors and fuel pump on Perkins 903.27? #4
Sure u can send it to me.. BUT.. that pump & injectors is no easy process to remove.. the front of the engine has to come apart to get the pump off & it HAS TO BE timed using special timing pins.. its no easy task..& very intrusive..
The pump removal is taken off as a last resort.
The injectors are under the valve cover & again.. not an easy task..
These aren't something that is normally done by a "home owner".. it takes special tools & knowledge..
So, it sounds like, "Leave it alone unless there is something wrong".
Is there an easy way to check cylinder compression?
   / Howdo I check the injectors and fuel pump on Perkins 903.27? #6
Your absolutely right.. don't mess w/ it..
& no, theres no easy way to check compression.. the injectors are under the valve cover & intrusive.
The v.cover has to be removed, the inj. removed & u have to find an adaptor that mimics your injector..
   / Howdo I check the injectors and fuel pump on Perkins 903.27? #7
Let me see if I got this. The thing has run flawlessly and still does. Ahem If it ain't broke don't try to fix it.
That's about right but, I might find something that needs fixing.
Go Sun Devils.
   / Howdo I check the injectors and fuel pump on Perkins 903.27? #10
Go Sun Devils.
More likely, you'll create something that needs fixing!
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2011 DODGE RAM 2500 (A52472)
2011 DODGE RAM...
2018 Volkswagen Jetta Sedan (A50324)
2018 Volkswagen...
Ford NAA Jubilee Tractor (A52748)
Ford NAA Jubilee...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
