Howdo I check the injectors and fuel pump on Perkins 903.27?
   / Howdo I check the injectors and fuel pump on Perkins 903.27? #1
def38
Platinum Member
woods and mountains of Alabama
M-F 231S
My M-F 231S is equipped with a Perkins 3 cylinder diesel engine which has run flawlessly since I bought the tractor used. I would like to check the injectors and fuel pump to make sure all is well. What do I need to do?
   / Howdo I check the injectors and fuel pump on Perkins 903.27? #2
Remove them & take them to a qualified shop for testing.
OK. Once I have them back, how do I insure no air is in the system? If the pump needs work, can I send it to you pumpguy?
   / Howdo I check the injectors and fuel pump on Perkins 903.27? #4
Sure u can send it to me.. BUT.. that pump & injectors is no easy process to remove.. the front of the engine has to come apart to get the pump off & it HAS TO BE timed using special timing pins.. its no easy task..& very intrusive..
The pump removal is taken off as a last resort.
The injectors are under the valve cover & again.. not an easy task..
These aren't something that is normally done by a "home owner".. it takes special tools & knowledge..
So, it sounds like, "Leave it alone unless there is something wrong".
Is there an easy way to check cylinder compression?
   / Howdo I check the injectors and fuel pump on Perkins 903.27? #6
Your absolutely right.. don't mess w/ it..
& no, theres no easy way to check compression.. the injectors are under the valve cover & intrusive.
The v.cover has to be removed, the inj. removed & u have to find an adaptor that mimics your injector..
   / Howdo I check the injectors and fuel pump on Perkins 903.27? #7
Let me see if I got this. The thing has run flawlessly and still does. Ahem If it ain't broke don't try to fix it.
That's about right but, I might find something that needs fixing.
Go Sun Devils.
   / Howdo I check the injectors and fuel pump on Perkins 903.27? #10
Go Sun Devils.
More likely, you'll create something that needs fixing!
Deutz 2WD 53HP Utility Tractor (A51691)
Deutz 2WD 53HP...
2007 Peterbilt PB340 T/A Roll-Off Truck (A50323)
2007 Peterbilt...
2013 INTERNATIONAL SA615 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2013 INTERNATIONAL...
2016 Isuzu NPR-HD Morgan 24ft Box Truck (A50323)
2016 Isuzu NPR-HD...
2011 DODGE RAM 2500 (A52472)
2011 DODGE RAM...
2012 Mack CXU613 Day Cab T/A Wet Kit Truck Tractor (A50323)
2012 Mack CXU613...
