howard
   / howard #2
The fan blet runs off the hydrostatic pump pulley to the fand drive gear box. It has a spring loaded idler. Raise the cab to get access, then pull the idler/tension pully towards you to loosen belt. Slip the belt off both pump and gear box pulleys. Take the bolt out of the idler pulley to get blet out from under the retainer guide to replace it. Also replace the bushing inside that pulley while you're in there.
2024 PETERBILT 389 TANDEM AXLE SLEEPER (A53426)
2024 PETERBILT 389...
City of Buckhannon Onan 200 Set Stand By Generator (A52384)
City of Buckhannon...
2013 Dodge Charger Sedan (A52377)
2013 Dodge Charger...
1999 MORBARK 3800 WOOD HOG GRINDER (A53426)
1999 MORBARK 3800...
7ft Fork Extensions (A51691)
7ft Fork...
2018 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2018 John Deere...
