How would you measure tip speed on a hydraulically powered mower blade?
   / How would you measure tip speed on a hydraulically powered mower blade? #1
MossRoad
Super Moderator
South Bend, Indiana (near)
Power Trac PT425 2001 Model Year
This seems like an interesting project.
The question came up to me of "what is the tip speed of your mower blades?"
The mower deck is hydraulic, so the only shaft I could measure speed on would be the shaft coming out of the hydraulic motor. The center spindle is direct driven by that shaft, so it would be accurate.
I used to have access to a tachometer that has a wheel I could press on the shaft to get speed. Then I could calculate from that. I don't have access to that tach anymore.
How would you go about measuring the RPMs of that shaft?
   / How would you measure tip speed on a hydraulically powered mower blade? #2
Tachometers are pretty cheap for entry level ones. Do you know the flow into the motor and the motor volume?
Yes, but that can vary with throttle on the engine, which varies the RPMs of the pump, affecting flow calculations. I'd need an engine tachometer and assume that the 20 year old pump and motor, and hoses, valves, etc... have no leakage, slippage etc....
I'd like to measure right at the beast itself. ;)
White paint strip and an adjustable strobe light?
   / How would you measure tip speed on a hydraulically powered mower blade? #8
A hall effect sensor. You can buy one for about $10 on Amazon. You'd have to wire it up to a monitor, though. Or, you could buy one packaged as a bicycle cyclometer (speedometer), for about $20-$30. Simply place/fix a small magnet on the blade, and place the sensor within about 1/4" as it passes by. If you go the bicycle speedometer route, you'll have to back out RPM based on the circumference of the "tire" that is set on the cyclometer. V = RPM x pi x D. Just be careful with units when making the calculation.
I guess that was too easy. I'll be looking at a few and get one sometime in the near future and report back. Thanks.
2001 Volvo A25C 6x6 Haul Truck (RIDE AND DRIVE) (A50775)
2001 Volvo A25C...
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
2015 Honda Accord Sedan (A53424)
2015 Honda Accord...
Vermeer 840 Discbine (A50775)
Vermeer 840...
2018 John Deere 325G (A47477)
2018 John Deere...
