dfkrug
Super Member
- Joined
- Feb 3, 2004
- Messages
- 7,594
- Location
- Santa Cruz Mtns, CA
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
There is no question that the B21 is an integrated TLB and the CK30 I have is not. The big difference is I
have to switch seats to use the hoe on the latter.
The B21 uses a diverter for hydraulic power to the hoe, which is a better way to go, tho the Kioti
approach works OK.
As for the underpinnings of the 2 machines, I have pointed out to Kioti and others that the CKs have
a very vulnerable hyd system underneath, which I have protected with my custom subframe. The
B21 has a big and separate hyd reservoir with a flat bottom underneath. Its ground clearance is
a bit less due to smaller wheels.
Kioti's OEM subframe for the 2475 provides some underside protection, but I do not like how far it makes
the hoe stick out back. The departure angle of my CK setup is better, and I STILL hit the ground
on some places on my property. The B21 IS smaller and more maneuverable with better departure angle.
