Tires How wide to set rear tires.
   / How wide to set rear tires. #21
The valvestems will be on the inside which is not really a problem.
   / How wide to set rear tires. #22
John Deere in no uncertain terms states to always use the widest wheel setting when the loader is used. Having said that my 4310 was delivered with the narrowest setting. The tractor has 12.4x24R1, which are not a big deal to set. I have since got the 15x19.5 R4 for summer use. I swap twice a year, by myself. The way I do it is to drop the bucket to the floor to aid with stability. I then find a reasonably flat spot under the drawbar mounting to place my floor jack. I proceed to lift the rear of the tractor barely off the floor. Grab hold of the fender and try to rock the thing to see how stable it feels. In my case the tractor will set fine on the floor jack with only one rear wheel in place and in the air. As you will be going wider it is a good idea to stick a jack stand under the axels for a safety net. Probably no room when going narrow. I roll the wheel up to the tractor and tip the top out to me. I then work it back and forth until it is under the wheel hub flange, not too far, because you need room to straighten it upright. When it is set back up it should be one to two inches out from the flange. Continue to work back and forth until it is ready to go on the flange. Keep fingers and arms away from the top of the wheel under the fender. If both wheels are removed then the most hairy part will be to get one wheel on with a couple of bolts. after that you own it. Should be down hill. Good luck.
Thanks for the tips guys. Will let you know how it all works out.
2006 Gehl RS5-34 6,000lb 4x4 Rough Terrain Telehandler (A55851)
2006 Gehl RS5-34...
2007 Ford F-450 4x4 Cab and Chassis Truck (A55852)
2007 Ford F-450...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2022 John Deere 5075E MFWD Tractor (A53485)
2022 John Deere...
UNUSED FUTURE FT13CJ EXCAVATOR (A57192)
UNUSED FUTURE...
