How/Where To Route Hydraulic Hoses With Backhoe Removed?
   / How/Where To Route Hydraulic Hoses With Backhoe Removed? #1
snymat68
Platinum Member
Monroeville, PA
RK24H, Gravely 8123
I removed the backhoe from my RK24 last night to move some 3point attachments around.
On the tractor end, I connected the two lines back together to form the loop, and capped the third one.
I had a heck of a time trying to figure out where to route and/or stow these hoses at that point, as they were hanging down between/around the lift arms and PTO.
I ended up stuffing them between the back of the seat and the cross bar that the orange triangle is bolted to, but that didn't seem like a very clean solution.
What is the proper way/place to route/stow these hoses? :confused: Thanks! :)
   / How/Where To Route Hydraulic Hoses With Backhoe Removed? #2
Welcome to the privilege of BH ownership. MF GC Series has the same issue - they give you enough slack to properly connect the BH hydraulics, but give you no provision for hanging or otherwise securing the hydraulic loop or tank line. Mine are tucked up, but out of range of the top link and I use bungees to the ROPS base under the body work.
   / How/Where To Route Hydraulic Hoses With Backhoe Removed? #3
Rule #37: If duct tape or baling twine won't hold it together, use a zip tie.
That's similar to rule #16...
If it moves and it shouldn't, duct tape.
If it doesn't move and it should, WD40.
BAT WING SHREDDER (A58216)
BAT WING SHREDDER...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A58018)
2020 INTERNATIONAL...
2010 Chevrolet Tahoe SUV (A56859)
2010 Chevrolet...
PALLET OF MIXED IRON, ROUND STOCK, FLAT SQ TUBING (A52708)
PALLET OF MIXED...
TANK MANIFOLD (A58214)
