Mowing How well does the 60" mow?
   / How well does the 60" mow? #11
Just an outsiders view, but the Kubota FEL specs arent nearly as good as the Deere.
look more closely at the spec sheet. Deere use the pivot pin measurement which makes it look like a big difference. If you compare at the same points they are within 10% of each other.
   / How well does the 60" mow? #12
Its not as fast a our zero turn but it does a superb job and will go almost anywhere with that great cut. My son puts in about 30 hours a week with the BX2670. So I vote for the Kubota or the Kubota it has 140 hours on it and the ZD has over 600
Heavy Duty D-Ring Shackles (A55852)
Heavy Duty D-Ring...
2013 Freightliner M2 106 Stellar 12621 6-Ton Mechanics Crane Truck (A55852)
2013 Freightliner...
(2) SPACE-RAY INFRARED HEATERS, INDUSTRIAL (A57192)
(2) SPACE-RAY...
2020 TCTC 16ft T/A Landscape Trailer (A55853)
2020 TCTC 16ft T/A...
cummins generator (A56857)
cummins generator...
2016 Ford F350 (A55973)
2016 Ford F350...
