How too fix my lawn.
   / How too fix my lawn.
I have the same problem over here near Starbuck. Our yard is bowl shaped and on wet years like we've had with the exception of last year, the yard has not dried up enough to support the weight of either my Ford or Oliver. Just like your ruts, mine come from the front tires bearing the weight of the FELs. I'll be watching this thread with great interest because if you gain a solution for your problem I may have one for mine. In my case, I suspect the soil type is a major factor. We have what is known as Osbourne Clay. Don't ask me how that differs from other clay.:confused2: I just know it is challenging to deal with and when wet, sticks like iron filings to a rare earth magnet and will not let go!:laughing:
Because I have so many low areas to level, I had some 3000 cubic yards of drift soil hauled in from a neighbouring field after the municipal people had done drainage management. Come Spring and the conditions permit, I will be using some of this to spread over the ruts as well as fill low areas to encourage drainage. Disking and harrowing until the soil is even and somewhat compacted is probably how I will go about it once the drift soil is spread. Since you are on the East side of the Red River from me, you are likely dealing with a different soil type. Do you have ready access to earth to fill your ruts? What about equipment for leveling? I hope to get a drag built to even out the gravel driveway and yard. I can see that being useful as a finisher after harrowing the parts of the yard that I have worked up.
For leveling I have a couple of back blades nd different sizes of box blades. I have a tiller but I don't really want to till it all and start from scratch. I think filling with soil stolen from the tree lines is going to be my fix.
   / How too fix my lawn. #12
I'm following this thread with great interest.
We had a well drilled last week and the rig left some pretty deep ruts. The ground was soft due to the snow and rain we'd had in the week before).
The first try resulted in the Deere 4400 sinking in as well. I had to use the bucket curl to push me out. I could get the ruts closest to the parking area (hard packed gravel) so I'd have some traction (turf tire and 4 link ladder chains). This was using the loader to move the mud and back dragging to fill. It worked OK.
The following day (after a below freezing night), could could run on the area and got the remainder of the ruts. Once I broke through the frozen crust...well, that was about all I could do.
My plan, once the area is a it drier, is to use a roller to pack the mounded dirt down. Doesn't look near as bad as it did originally...but it is a work in progress.
   / How too fix my lawn. #13
i'm going to build one of these, (but with 4" spikes) partly to decompact areas of my lawn where the grass is having a hard time penetrating compacted soil, partly to smooth things out, which i'm hoping it will do.
i don't really have a lot of ruts, but the thinking is that the spikes will push the edges of whatever ruts i have/create, inwards.
it would definitely have to be done with damp ground, but with repeated uses... maybe the ruts will be filled from the surrounding soil?
   / How too fix my lawn. #14
The ruts at my place do not seem to have a ridge on each side. So for me to try using a roller is pointless. I don't know if that is an unique function of the clay soil or not. My ruts were formed as I mowed and baled the hay. Of course the hay was unfit for feed but I was using it as cover for frost protection.
   / How too fix my lawn. #15
I did landscape for ten years and we always had this issue when doing work especially around lake lots. The best bet and easiest by far is to fill with topsoil route. Rollers will work but the land has to be literally saturated and usually the implement you have to use to pull it only creates more ruts.
Go with the topsoil topped with cool season fescue and you should be good to go.
   / How too fix my lawn. #16
A plug aerator with a lot of weight on it will do a great job. Wait until the ground is a little soggy. If this doesn't work you may have to use a box blade and mess up the grass.
   / How too fix my lawn. #17
How about renting a 3pt tiller for your tractor and tilling the entire area and then regrade and reseed it to make a brand new blemish free lawn area.
Not sure how picky you are but Ive filled ruts like that before with more loam and reseeded them and the ruts always seem to show up in the grass later on
and can make for an eye sore but if its a back field then hey what the heck.
To me the only repair for me would be a full redo.:thumbsup::2cents:
My ruts don't have ridges either. At first when the ruts were more noticeable I would try and run over the edges with the tires. Now its just all bumpy.
What's "cool season fescue"?
I was thinking the same thing about the tractor trying to pull a loaded roller and making new ruts.
   / How too fix my lawn. #20
I go through this every year from putting all our critters in our smaller pasture with barn access for the winter. It takes them about 2 weeks to have it beat down to a rutted up mud pit. As soon as it is dry enough they go into their bigger pens and I get started on fixing that one.
The first year we had a friend with a sub compact John Deere and 4ft tiller come out to till it for us (took most of a day). Then I pulled around a makeshift land plane I made from old rail road ties with my lawn tractor to level it out the best I could. Then followed up with the small roller I had to pack it down. I did not seed. The grass popped back up in three weeks and after one mowing to get everything even it looked better than my lawn and was nice and smooth.
I repeated the process the next year with a borrowed Kubota compact and 5ft tiller and rear blade instead of my makeshift land plane. While I had the Kubota at my house I stole my dad's roller which is 7ft wide 24" OD filled solid with concrete. This made the results even better and only took a half day. Grass recovered in the same amount of time with no seeding.
This year its game on now that I started my "real job" and have the money to throw at projects I have been putting off. I plan on reworking the whole yard now that I have my own toys to do it with. I picked up a ct28 McCormick 4x4 with fel at the end of last summer and have been picking up the implements as I come across them. I picked up a 72" tiller for it and plan on getting a real three point land plane by spring. My thinking is I can use some chains to drag the land plane behind the tiller to kill two birds with one stone. I also made a rack on the roller to put two big concrete blocks I plan on making on top of it to really compact things for the yard. I think I will actually re-seed the yard unlike the pasture. I may even bring in some dirt from the back 40 to fill in some low spots before I start the process.
I will let you know how it turns out in a couple months.
New Holland B95 Backhoe (A50490)
New Holland B95...
2019 CATERPILLAR 308 CR EXCAVATOR (A51242)
2019 CATERPILLAR...
2020 Ford F-250 Ext. Cab Pickup Truck (A50323)
2020 Ford F-250...
2021 Takeuchi TL12V2 Skid Steer (A51242)
2021 Takeuchi...
2021 CATERPILLAR 279D3 SKID STEER (A51242)
2021 CATERPILLAR...
2021 Liebherr L556 (A52128)
2021 Liebherr L556...
