Backhoe How to videos
   / How to videos #11
Yes you can purchase them from the dealer. As far as caps there are companies like tisco, and high capacity that sell universal caps for hyd. lines. Pretty cheap also.
   / How to videos #12
I got my caps at TSC.
   / How to videos #13
The first time I did mine it came off without a problem, getting it back on was another matter. I left the stabilizer legs out supporting the backhoe and the arm extended. I did place a cinderblock under the assembly after I pulled away from the unit. Came back in a week and could not get the hoses to connect. There was still pressure on the hydraulic hoses which thwarted any attempt at reconnecting the quick disconnects. I now "relieve" any pressure on the hoses before disconnecting them. Once your backhoe is free from the tractor shut it down and wiggle every valve on the backhoe - it will settle some as the fluid pressure stabilizes. Then pop your quick disconnects..... When you go to reattach you will not have to do what I did and Loose a fitting to reconnect.
Hope this helps
   / How to videos #14
fun day when you gota slam fittings against metal to release pressure.. talk about a mess
or risk taking it out at the cyl. lol
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2012 CATERPILLAR 304E CR EXCAVATOR (A51242)
2012 CATERPILLAR...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
2017 John Deere 1025R Tractor - 626 Engine Hours (A55314)
2017 John Deere...
2016 Ford F-150 4x4 Pickup Truck (A54814)
2016 Ford F-150...
