How to "undercoat" mower deck.
   / How to "undercoat" mower deck. #71
I'm all for good maintenance but there is a matter of value. How many rusted through decks have you seen. I've seen cracked decks and bent decks but not rust holes.
Yeah, I've not had any rust through either. My problem is the deck clogging up with grass even when "dry".
   / How to "undercoat" mower deck. #72
The deck on my previous tractor (1978 JD 850) had the belly mower patch several times where it wore or rusted through.
I recently repaired several rust holes and built new baffle plates (original baffle plates were gone) on my 1978 Wheel Horse garden tractor deck
   / How to "undercoat" mower deck. #73
I have always heard Deere decks rust through quicker in part because they are thinner and stamped which adds a lot of residual stress,i.e. energy to speed the corrosion. The other side is that the stamped decks have smoother flow lines so that the grass should not have the corners to end up in. Then of course some say you only notice it on the Deeres because the tractor lasts longer.
What i do know is that if the grass sticks on and stays wet it will rust - if it is always clean and used regularly it will not rust. If it is not being used it should be coated.
   / How to "undercoat" mower deck. #74
My mower has 160 hours on it. Much if the underside paint is gone. It is always stored indoors, and I never see rust
   / How to "undercoat" mower deck. #75
This may have been suggested...I didn't read the whole thread...
...But you could get a couple cans of spray on undercoating..shake them up real good...then with a mulching set up just run over the cans...easy peasy...!
   / How to "undercoat" mower deck. #76
I now scrape and spray oil under my decks at the end of the mow season to stop any rust
  • Good Post
Reactions: JJT
   / How to "undercoat" mower deck. #77
   / How to "undercoat" mower deck. #78
"It's time to start cooking mowing with PAM®" ???
   / How to "undercoat" mower deck. #79
40 plus years for a Deere and Wheel Horse, I'd be bragging also. (y)
   / How to "undercoat" mower deck. #80
Having owned a 1979 Chevrolet C-20 Pick-up, I will also attest to the fine quality of American steel of the era.
2018 John Deere XUV560E 4x4 Gator Utility Cart (A53421)
2018 John Deere...
2007 Freightliner B2 School Bus (A55852)
2007 Freightliner...
5' ROTARY MOWER (A52706)
5' ROTARY MOWER...
2025 JMR Tree Boom Skid Steer Attachment (A55851)
2025 JMR Tree Boom...
2017 DRAGON 150 BBL ALUMINUM TRAILER (A53843)
2017 DRAGON 150...
UNUSED 10PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 10PCS...
