How to transition to MIG?
   / How to transition to MIG?
Most of the welding I've done or am likely to do is either fabbing up stuff for my shop/tractors/equipment or repairs. Likely things like 1/8 - 1/4" angle and flat stock or round tube mostly. I've done things like replace a rusted frame on a small utility trailer, build my own welding table, weld up a frame for steps for a camper, build brackets for my MC510 cart's hydraulic dump that I added, tools and jigs for shop work. Unlikely to be any sheet metal or non-steel, though maybe aluminum some day.
I've tried 6010, 6011, 6013 rods. 6011 and 6013 have worked decently, 6013 the best. 6010 is a miserable failure that I can't get an arc struck with. I think I bought the 6010 accidentally without realizing they are mostly for DC welders. Never tried the 7014.
I want more precise control of the weld and better looking welds. Like I said initially, most of what I weld is structurally sound but the welds are a bit messy with a lot of splatter.
Rob
   / How to transition to MIG? #12
I think you are an excellent candidate for a MIG welder.
I used my Lincoln tombstone welder last Summer to burn 3 7018 rods on a disc repair. I can't remember the time before that. Got it if needed, just rarely needed.
I will say my 250 might be a bit big for you. Lots harder to weld thin metal.
The 175A range seems to be the most widely used.
   / How to transition to MIG? #13
Might want to do a little viewing of site link below of curious about MIG
Welding Tips and Tricks - TIG, MIG, Stick and a pantload of other info
I transitioned from stick to MIG after selling old tombstone Lincoln... Love the MIG, so much simpler, and only thing to relearn was how focus arc to ensure getting good penetration and weld area prep is a little fussier (clean steel)....
I have Hobart Handler 140 (120V AC machine) but seriously thinking of selling and going to a dual voltage (120V/240v) machine to get the bigger amperage for bigger materials...
Whatever you do if you go MIG is get a machine the will do FCAW (Flux Core Arc Weld) and GMAW (Gas Metal Arc Weld)... Might even consider a combo machine the can do Stick, MIG. and TIG then you can have best of all worlds....
Dale
   / How to transition to MIG? #14
Thanks for the tip. Does the Hobart 210MVP have that auto speed capability? That's the one I've been eyeing. Seems like it is pretty capable and highly regarded and also only about half the price of the Miller 211.
Rob
No... All manual settings.... BUT it's a really good machine once you learn its operation....
Dale
Thanks for the tips, guys. I'll follow up on the suggestions.
Rob
   / How to transition to MIG? #16
This is a great topic. You should get a LOT of response. There are several Craftsman Welder Guys on here!!!
MIG is much easier to use than stick. Your technical questions can only be answered by knowing your expectations in regards to thickness of metal, etc.?
Hobart makes a nice affordable 140A MIG welder that will use gas/solid core wire or flux coated wire. I'm not pimping Hobart but they are readily available and expendables are easy to find. With that Amp range you'll probably use .030 wire.
This is just me now. I wouldn't buy a 110V MIG welder. Just like if I thought I needed a 30hp tractor I wouldn't buy a 25HP. Since you already are welding you have a need. Buy a brand name, 220V, 140A minimum, gas capable welder. You'll love it.
If Mark from Everlast gets in here he'll give you very logical, sensible advice whether you buy his brand or not.
Edit: I have a Miller 250 that I run .035 wire with 75/25 gas.
It seems as thought the Hobart Handler 190 MIG (220V only) might be a more cost effective option for the OP.
TSC lists it at $649.99, and it is a great machine.
Lots of very poisitive reviews!
   / How to transition to MIG? #17
I have been welding with stick as my only method for many years. Not that I'm good at it or have done it a ton, but I can make metal stick together passably. It doesn't look great and I wouldn't stake my life on the results but most of my projects are non-critical and they hold up fine. :)
Stick welding is a pain though, probably because I'm not that good at it. Sometimes it is hard to strike an arc. Probably using the wrong type of rod. And I probably should get a better helmet that is auto-darkening so I can see what I'm doing before I strike the arc randomly an inch away from where I'm supposed to be starting. I know I have some challenges overall. Going to work on those. My welder is an ancient (30-40 year old) Lincoln buzzbox. I think it is in decent condition but I guess it is possible that it may not be in tip-top form itself so that may contribute to my pains. I have replaced the leads and ends recently.
But I'd like to get into MIG welding. It seems like it may be a little easier to control things and not be as futzy as stick welding. Is this a reasonable thought? Does anyone have a pointer for someone who knows the general concepts of welding to get up to speed on MIG? Things like choosing fluxed vs. non-flux wire, what gas is needed, wire thickness to choose, wire speed, etc? I'd like to learn about it before buying a new welder.
Thanks,
Rob
Mig is a good process - I use it as much as stick and tig. Faster to learn too.
Hard wire 0.030" (gas shielded) will do about anything you want - even outside. If it's windy, lean a piece of plywood up against the item to block it.
I use 0.030" and 0.035" way more than 0.024". I just used 0.035" for body panels a few months ago and it worked fine.
I use 100% co2 for shielding because it's cheap. Standard mixed gas works great too.
There is almost no need to get more fancy that regular mig wire, and 71t-11 self shielded flux core (for when you really can't use shielding gas).
In my opinion, everything else is just for goofing off and seeing if you like it (like spray arc or gas shielded flux core or pulse mig, etc.).
There are a few things to know. Wire feed speed is your amperage - it controls penetration (depth of fusion).
Voltage controls bead profile. If a bead is tall and ropey, increase volts to widen and flatten puddle.
If arc is spattery and unstable, bead wide and flat, lower voltage until it runs right.
Stay on the leading edge of the puddle. If you don't actually see the arc cut into fresh metal, then assume it didn't.
If you're just an occasional welder who fixes things as needed, you'll likely really like mig. Get one in the 180-200 amp size and weld happy :)
   / How to transition to MIG? #18
Another vote for the Hobart Mig. I had the predecessor to the 190 (187) and it was a great little welder.
I would love to try an Everlast MIG machine if I had the chance.
   / How to transition to MIG? #19
90day wty i not good for the HF unit, although you can buy an extended then you are getting up in price - just FYI get waht you can afford - id stay away from the 110 units unless price is an issue as most folks wish they had the 220v more amperage option later - again depends on how much you want/have to spend - u have lots of options for aluminum not just tig but if you go tig you will need an AC machine for tig not DC tig so remember that
u can weld aluminum with a mig/spool gun although typically not really thin aluminum from my understanding - oxy acet for aluminum and also stick weld aluminum, tig will of course do the prettiest from what i have been told i dont do it i would just have someone else do it.
flux mig will give you splatter like arc/stick just not as much so keep that in mind - to get the cleanest u will want gas
if you are building new stuff u will likely grab your mig, if you are fixing rusty old broken down stuff and in a hurry you will grab your stick
   / How to transition to MIG? #20
I had that same welder, I found it ran 7014 and 6013 very well, I could make semi decent welds with 7108AC but I never loved it. But I've also welded alot of stuff that was welded very well and it has taken alot of abuse and never failed.
Having taken several welding classes and done alot of welding work I knew I could weld better with other welders and was never pleased with that Lincoln 250 amp a unit, but the budget I had when I bought it that's what I could afford and I knew it would work.
I first bought a 140 amp Everlast mig, it work swell up to 1/4" steel, will do 3/8' if beveled out well, but I mainly bought it for 1/" and smaller stuff and to tack stuff together, namely horseshoe art kind of stuff. I later bought an Everlast 200 amp DC stick welder and absolutely love it, much easier to weld every rod with than the Lincoln Tombstone ever did, dual 110/220 voltage but I'm not impressed with it on 110 and only use it on 220, but at the inrush currents it has It can run on just about any 220V outlet.
The Lincoln Tombstone went away pretty fast, I put a price on it for someone really needing a good welder with a really low budget.
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A48836)
IMPORTANT PLEASE...
International 574 Tractor (A50860)
International 574...
Equipment Location (A50490)
Equipment Location...
New/Unused Pallet of 5 Binder and 10 Chains (A48837)
New/Unused Pallet...
2 Vintage Metal Signs (A48081)
2 Vintage Metal...
2004 Komatsu WA75 Wheel Loader (A50397)
2004 Komatsu WA75...
