How to tie knots when pulling trees?
   / How to tie knots when pulling trees? #11
frank29 said:
Thanks to all! Maybe my rope will stop getting shorter; about every other tree, I've been getting frustrated and just cutting right at the knot.
Thanks again.
Oh-Yeah, till the bitter end.......... hehehe!
   / How to tie knots when pulling trees? #12
I still have a bunch of big old "hemp rope" that wo'n't quit, but is hard to un-knot, so I tied on a short length of very dense nylon rope which with the right knot on the tree tends to untie much easier. Cheap fix for me.
   / How to tie knots when pulling trees? #13
I go with what Highbeam said - that's how I see the professional tree "fellers" do it
   / How to tie knots when pulling trees? #14
TwinWillows said:
If you have to use a rope instead of a chain or cable the knot I'd recommend is called a timber hitch. It's not hardly a knot in the truest sense as the "dead" end of the rope is just looped back & then wrapped around it's self several times. The friction of the rope wrap on the bark will hold it in place.
Timber hitch - Wikipedia, the free encyclopedia
This shows how to tie it.
Hmmm.... what knot to use to pull trees.... hmmmm.... Timber hitch..... hmmmm...... trees = timber..... hmmmmm..... :D
We were taught that one in Boy Scouts. It is such a simple knot, takes only seconds to tie, and loosens up easily. I use that one a lot. One of the top knots to learn, in my opinion. :)
   / How to tie knots when pulling trees? #15
When I used to be an arborist, I found you really only needed four knots.
A clove hitch, a bowline, a running bowline and a taut-line hitch.
Two extra's that are nice to know are a truckers knot and a bowline-on-a- bite. A truckers knot is very nice for tying down loads when you need to pull a rope tight and lash down something. A bowline-on-a-bite is nice for putting a loop in the middle of a rope that you can easily get undone later.
   / How to tie knots when pulling trees? #16
Get a chain. Having a rope snap is no fun.
   / How to tie knots when pulling trees? #17
AlanB said:
Bowline
The Bowline
Best knot site I have found, There are lots of other knots on there, but really the Bowline is the one to use.
This is a great sight, Had to save that 1 to my favorites,
Thank You
Charlie
   / How to tie knots when pulling trees? #18
Find a preacher that makes house calls? I must say though I think it's inappropriate to be get married while you're pulling down a tree but to each his own I guess. Also, don't tie the knot multiple times. Well, at least not more than one at a time.
I really appreciate the advice given....especially the bowline and timber hitch. This past weekend I got back to cutting down trees. I used the bowline most of the time and remain amazed at its simplicity to tie and the ease of removal after the tree falls.
Thanks!
Wright Sentar (A50120)
2017 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A54313)
2017 FREIGHTLINER...
2016 KENWORTH T270 S/A SERVICE TRUCK (A51247)
2016 KENWORTH T270...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
air compressor (A55758)
air compressor...
