How to test Hydraulic pressure
   / How to test Hydraulic pressure #1
John deere Chris
Ri
1980 john deere 300B
Hi I have a 1980 john deere 300b with some hydraulic issues. Only at full rpms do the loader and backhoe function with few issues. When brought back to a idle the hydraulic controls continue to work for the next 5 minutes then stow down and eveuntaly stop. I would like to check the hydraulic pressure of my pump. I have the tool just was wondering how to hook it up and test, and where to hook the tool up,for an accurate reading. Thank you and god bless!
   / How to test Hydraulic pressure #2
Chris, I have a video on my website showing the process, but I suspect your machine has Closed Center Hydraulics and probably no QD's ports to plug into I can't advise the correct procedure. You might want to check eBay for some technical manuals for your machine to be sure of the proper way to do it, and what the specs should be.
   / How to test Hydraulic pressure #3
Yes 300B is closed center hyd's just tee into any high pressure hyd supply line to get stand-by pressure
2016 Nissan Pathfinder SUV (A50324)
2016 Nissan...
1993 Barrett Gooseneck Livestock Trailer (A50514)
1993 Barrett...
UNUSED AGT YSRT14 STAND ON SKID STEER (A51243)
UNUSED AGT YSRT14...
UNUSED FUTURE SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE SKID...
197711 (A51244)
197711 (A51244)
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
