How to tell if hose is Propane ready from Oxy setup
   / How to tell if hose is Propane ready from Oxy setup #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
I just had a nice turn of fate. My neighbor builds steel buildings, and has a bunch of Oxy Acetyelen systems in his shop. He buys them all the time and they end up on the floor of the shop. He is giving me regulators, hoses and the controls. I will need to buy tanks (he has tank carts but leases tanks).
Anyway, how do I tell if a hose is ready for Propane, and from what I understand here it would take a few years anyway for the hose to be effected. Any thing else I need to look for? I will have to buy a tank, but a new setup at the welding supply is $400 plus tanks...
Thanks
Carl
   / How to tell if hose is Propane ready from Oxy setup #2
Look at the stamping on the hose, an acetylene only hose will be grade R. A multi fuel hose will be grade T.
   / How to tell if hose is Propane ready from Oxy setup #3
propane cutting may be okay on a gang torch cutting table with new steel, but you aren't going to have any fun cutting up things that are rusty, coated with tar or other sorts of things... it just doesn't have the preheat capability that acetylene does.
i cut up a rusty old dump box off a 5 ton truck that had been used as a sander in the winter. swore i would never use a propane cutting torch again.
rjmack
Your comments are interesting. Everyone I have spoke to has gone in the other direction. They say cutting is great, but pre-heat takes a longer moment and you need to relearn your sweet spot in the flame. Also from what I get the reason propane is less loved for welding / brazing is due to the air around the flame. Something is different, where acetyline provides a shield, propane does not.
Even our oxy dealer, a major national chain, recommended propane.
But you are not the 1st one to have said watch out. I am going to go for the propane and will let you know how it turns out.
Carl
   / How to tell if hose is Propane ready from Oxy setup #5
rjmack
....... I am going to go for the propane and will let you know how it turns out.
Carl
Thanks, I have been thinking about doing the same thing. Will be watching for you results
DRL
2014 Club Car Electric Utility Cart (A51694)
2014 Club Car...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
Electric Mobility Scooter (A51694)
Electric Mobility...
2022 Forest River Cherokee Grey Wolf 26BRB Patriotic Edition 32ft. T/A Travel Trailer (A51694)
2022 Forest River...
UNUSED GREAT BEAR FORKLIFT JIB (A51248)
UNUSED GREAT BEAR...
HAMM HD+ 120I DOUBLE DRUM ROLLER (A51246)
HAMM HD+ 120I...
