How to Tell if Front Axle Bearing is Bad?
   / How to Tell if Front Axle Bearing is Bad? #1
Suburban Plowboy
FL
Kubota L3710
My Kubota L3710 released some oil from the left front hub. Not much. I topped it off and ordered parts so I could replace a seal, an O-ring, and two bearings.
My understanding is that if I jack the wheel up and wrestle with it, and it doesn't seem loose, I can keep using the tractor until the parts get here. Is that true?
   / How to Tell if Front Axle Bearing is Bad? #2
If bearings are bad you should feel some play when trying to rock it or wrestle with it. Depending on how bad could also feel rough when turning the wheel.
Thanks. I am wondering if I can shoot something in there to seal the leak up so I can fix it when the weather is cooler.
   / How to Tell if Front Axle Bearing is Bad? #4
Not without affecting all the seals common to that lubricating system.
   / How to Tell if Front Axle Bearing is Bad? #5
If minimal leak and bearings ate not bad you might be better to just keep adding oil vs trying something to plug the leak.
It has UDT in it. I was going to top it off with thicker oil, but somewhere I saw something about potential problems. I doubt it's true, but I don't want to be bitten in the rear end.
   / How to Tell if Front Axle Bearing is Bad? #8
I personally would think that in the colder climates the super udt would pay off. Because of the viscosity. But you are right it be difficult to keep in there with a small leak
   / How to Tell if Front Axle Bearing is Bad? #9
I would be cautious mixing UDT with gear oil. Not sure if there would be compatibility issues or not.
   / How to Tell if Front Axle Bearing is Bad? #10
That’s a pretty decent leak. Kubota is known to blow front axle seals. I’d switch to axle oil if in a warm climate. The seals aren’t too bad DIY, next to go will be the wheel bearing. Make sure you keep the front hub reservoir topped off.
2001 Club Car DS 6 Passenger 48V Electric Golf Cart (A53424)
2001 Club Car DS 6...
2018 JOHN DEERE 410L BACKHOE (A52706)
2018 JOHN DEERE...
2016 Chevrolet Cruze Limited Sedan (A53424)
2016 Chevrolet...
Honda EU3000is Gasoline Companion Inverter Generators (A55851)
Honda EU3000is...
John Deere 6120E (A50323)
John Deere 6120E...
MULTIQUIP WHISPERWATT MQ POWER 25 GENERATOR (A52706)
MULTIQUIP...
