How to tap into propane (iron pipe) line
   / How to tap into propane (iron pipe) line #61
Plumbers should be forbiden to work on anything past the gas stop valve or electric disconnect. They aren't trained so I don't understand why they are alowed to mess with it. My solution for those old booming appliances was extend the standing pilot accross all burners or larger than usual singles. I once did a furnace for a church that had paid multiple plumbers an absured amount of money trying to stop a furnace booming.
Do you remember the old diaphragm gas valves with the bi-metal safeties ? I lost a few eyebrows with those when I first started service work in the late 70's
   / How to tap into propane (iron pipe) line #62
In the old days you could tell whether they serviced gas boilers and appliances or installed ductwork. Ducts were all metal and tech's arms and hands looked like they had been in a knife fight. Hair on gas servicemens' face and arms was singed. Now and agin one's face looked like blackface make-up from messing with a sooted up heat exchanger.
   / How to tap into propane (iron pipe) line #63
Haha, I know exactly what you mean! Those old gas techs definitely had a rough go of it. It's amazing how much has changed in the industry. I've recently dealt with I-maximum gas company https://i-mаximum.com/ and noticed how modern companies have really stepped up their game with safer, more efficient systems. They offer great service for both gas and HVAC needs, without all the soot and burns.
   / How to tap into propane (iron pipe) line #64
Best go the propane supplier with you plans and they will tell you what is required to meet your/their needs. They will inspect it the installation before fuel is supplied.
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
1987 Ravens 45 ft. T/A Float Trailer (A53117)
1987 Ravens 45 ft...
2003 Big Tex 10PI...
Toro Workman MDX Utility Cart (A51694)
Toro Workman MDX...
2004 Caterpillar 345B Hydraulic Excavator (A53421)
2004 Caterpillar...
2016 CATERPILLAR 730C2 OFF ROAD DUMP (A51246)
2016 CATERPILLAR...
