How to take apart Hammerlock link
   / How to take apart Hammerlock link #1
JB4310
Super Member
Central CT
J.D. 4310 E-hydro
Does any one know how to take these apart, I have the 3/8 size which has split spring sleeve, which is obvious, with a little force the pin will push out.
This older 1/2" one has a solid sleeve in the middle and I can't seem to be able to push the pin out, these are pretty expensive in grade 80 or 100 which I think the yellow one is, I would like to reuse it if possible.
Thanks, JB.
   / How to take apart Hammerlock link #2
Press, vise/hammer. That's all I got.
   / How to take apart Hammerlock link #3
I dont know if they come apart. I spent a half a day trying to get one apart and never did. I even tried putting it in the press and it wouldn't move.
Bill
   / How to take apart Hammerlock link #4
You could cut away the pin with a hand held grinder with the slim discs and replace the pin with a graded bolt and lock nut.
I'd get the highest grade available if the application is a critical one.
   / How to take apart Hammerlock link #5
Perhaps some heat and a press. Are the outside pin ends peened over a little from use and could the sleeve be rusted on.:confused:
No, the pin moves freely about 1/8" back and forth. there is another smaller sleeve/retainer between the outer sleeve and the pin, everything moves around freely.
Tried pushing the pin out in a med size vise and broke the vise, didn't have enough thread in the vise and broke a couple threads off the end of casting the screw threads into. vise is OK now after some mods.
I do have a monster vise I can try, but I think there must be a trick, found some info on these things with Google search but nothing describing dis-assembly.
JB.
   / How to take apart Hammerlock link #7
I don't think they are supposed to come apart.
   / How to take apart Hammerlock link #8
Try calling a crane rental yard and see were the get there rigging from, and call them. Or look for a rigging supply company
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2016 FREIGHTLINER...
2012 JOHN DEERE 350G LC EXCAVATOR (A51242)
2012 JOHN DEERE...
John Deere (A50322)
John Deere (A50322)
2016 Takeuchi TL8 (A47384)
2016 Takeuchi TL8...
2003 Lincoln LS Sedan (A50324)
2003 Lincoln LS...
2010 MACK MRU613 GARBAGE TRUCK (A51243)
2010 MACK MRU613...
