How to spray several acres to kill dogbane/johnson/pigweed grass?
   / How to spray several acres to kill dogbane/johnson/pigweed grass? #21
   / How to spray several acres to kill dogbane/johnson/pigweed grass? #22
I've got this small sprayer. The instructions describe how to calibrate and mix herbicide.
  • sprayer LG-3025(FM1328).pdf
   / How to spray several acres to kill dogbane/johnson/pigweed grass? #23
From what I've been able to find I can spray 2,4-D and kill the offending weeds.
HOW to spray is my question.
I have a spot sprayer...but no spray bar. I can build one (seen several videos from people that have done it).
The bottle says something like 2 quarts per acre....how on earth do you figure out how to do that?
I've only ever spot sprayed roundup, like on a fence line, driveway, etc - get the leaves wet and move on. I mix at 3oz per gallon and just go spray.
I assume you catch the flow and measure it over say, 1 or 2 minutes and add in 5 heads (or whatever on teh bar) and then the speed you're driving? Sounds like a word problem from HS...
Will 2-4-D work on the dogbane/pigweed/johnson grass? Add something else to it?
Sounds like you're wanting to spray a hay field and not kill the "hay". Did I read that right?
This is a common problem. Like wanting to kill foxtails in hay -- nothing is selective enough to kill the foxtails without killing the grass hay too.
What is your hay? Typical here is a mix of alfalfa, orchard grass, and timothy, for example.
2-4-D will kill anything with a LEAF. Like alfalfa, clover, broadleaf weeds, etc. It's the classic lawn weed-killer. Won't kill things with a BLADE, like grass.
Roundup / Glyphosate is going to kill everything. It's "non-selective". If your plan is to kill it all and start over, go with Roundup.
I don't see any reason to ever mix Glyphosate with 2-4-D.
If you just want to spray your "hay" and clean up weeds with leafs, 2-4-D will do it but you'll only be left with straight grass hay. However, it won't kill other offending weeds with blades like foxtail if they're a problem. This might be a good plan for you and you could still overseed with alfalfa or some other better quality hay seed later to get a better quality "mixed" hay.
So WHAT you spray depends on what you want to kill and what you DON'T want to kill.
As far as the sprayer, you pretty much need to get your sprayer together and then figure out how much liquid you're putting down per acre. The pump rate, number of nozzles, pressure settings, ground speed, etc. are all variables. My 40 gallon TSC FIMCO special puts out right at 30 gallons per acre with the average ground speed I use. Once you have that figured out, the rest is easy. You'll have to experiment with your final setup to determine the average output per acre.
   / How to spray several acres to kill dogbane/johnson/pigweed grass? #24
If I’m not mistaken, all of those plants will grow faster than the hay. After you mow, let the weeds get a little growth then use a wick applicator set just above your hay and low enough to hit the tops of the weeds. It eradicated my johnson grass in 1 use. I used Roundup mixed 50-50 with water. You are applying a small amount of liquid so you need it strong.
   / How to spray several acres to kill dogbane/johnson/pigweed grass? #25
Gordon's Acreage Pro will economically solve your 3 listed items and a lot more while not killing your entire pasture. I run this on my 3.5 acre yard and it does a fine job.
   / How to spray several acres to kill dogbane/johnson/pigweed grass? #26
2020 DRAGON ESP...
2015 CHEVROLET SILVERADO 1500 (A58214)
2015 CHEVROLET...
1985 FREIGHTLINER DUMP TRUCK (A58214)
1985 FREIGHTLINER...
2007 Toyota Camry (A56859)
2007 Toyota Camry...
2017 Ford F-350 Ext. Cab Pickup Truck (A56858)
2017 Ford F-350...
UNUSED FUTURE ML32 - 32" MINI HYD MULCHER (A52706)
UNUSED FUTURE ML32...
