How to speed up Hydralics
   / How to speed up Hydralics #1
Ottodrome
I just got a White 700 tractor with a loader. The loader goes down quick but come up slow. The bucket takes forever to curl. Anyone know how to speed it up?
   / How to speed up Hydralics #2
HAve you checked your hydraulic filter. If it is dirty it could be the culprit.
   / How to speed up Hydralics #3
Besides a dirty filter.. it is possible that the GPM of the tractor's pump is just insuficient to run the loader with any speed. You could always add an aux pump to the tractor...
Soundguy
   / How to speed up Hydralics #4
You may want to check the pump pressure to see if the pump is working right also. As mentioned above, the filter is the first place to start checking.
   / How to speed up Hydralics #5
</font><font color="blue" class="small">( Besides a dirty filter.. it is possible that the GPM of the tractor's pump is just insuficient to run the loader with any speed. You could always add an aux pump to the tractor...
Soundguy )</font>
Can you explain this to me? Can you add this too any tractor? Does this boost the gpm so that bigger hydraulic attachments can be used? Thanks...Tony
   / How to speed up Hydralics #6
Most common aux pumps are either pto pumps, or front mount 'stinger' pumps.. though I have seen quite a few pumps added with a belt drive right to the engine.
Yes.. generally the pto and front pumps have a higher GPM than the tractors built in hyds for 3pt lift, and steering.. etc. Probably mostly due to size of the aux pump...
Soundguy
   / How to speed up Hydralics #7
Just a little FYI......Boosting pressure increases the work (force) you have. Increasing flow rate (gpm) will speed up the attachment.
Of course, they're kind of tied together...up the flow rate against a restriction and it will boost the pressure behind that restriction.
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
(10) 8' Treated Posts (A50515)
(10) 8' Treated...
2013 Dodge Journey SUV (A50324)
2013 Dodge Journey...
2015 Kia Sorento AWD SUV (A50324)
2015 Kia Sorento...
John Deere 960 Culitivator (A50514)
John Deere 960...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
