How To Shorten Comer PTO Shaft?
   / How To Shorten Comer PTO Shaft? #1
JimMorrissey
Southern Maine (now)
'05/'06 L39 TLB
I tried to hook up my snow blower to my L39 earlier today and found out that the PTO shaft was cut for my previous tractor, which had longer lower link arms, thus the shaft is too long. Has anybody cut one back that can provide some advice? I don't imagine it's rocket science..... I have a small manual from Comer, but it's all about lubing the joints and general maintenance. Any help would be appreciated.
   / How To Shorten Comer PTO Shaft? #2
Jim: Not really sure but I watched my FIL shorten trailer axles by cutting to length & then finding just the right sized pipe to slip over the axles...then he welded the sleeves onto the axles. Not sure if that would be the approved method for PTO shafts or not but it's something to consider. Good luck!
Jon
Funny....I did the same thing to replace and strengthen an axle on one of my trailers.
Pretty sure it's just a matter of cutting to length, but want to make sure I don't miss anything and ruin it.
Thanks.
   / How To Shorten Comer PTO Shaft? #4
Jim,
Take a look at this thread
and it will give you the "how-to" and even follow the link to another thread which references the Bush Hog site which has good info there as well.
   / How To Shorten Comer PTO Shaft? #5
Shortening regular PTO shafts is easy...lengthening, not so. Is the Comer a square shaft? If not, disregard what I say.
If you have access to an abrasive saw, like a Milwaukee or DeWalt that has a 12" or so cut-off wheel, just cut equal amounts off the inner and outer driveshaft pieces and dress up the edges with a file.
If you were close, I'd loan you mine or you could bring the shaft over.
   / How To Shorten Comer PTO Shaft? #6
</font><font color="blue" class="small">( just cut equal amounts off the inner and outer driveshaft pieces and dress up the edges with a file.)</font>
cp is correct...
My Howse bushhog has instructions that mention to do that if the shaft is too long. (Fortunately, I did not need to do that.) I believe you could use a sharp hacksaw if you could keep the cut reasonably square, but a cut-off wheel would be much easier.
Got it...Looks pretty simple.
BTW, I did search and as usual found nothing via TBN "search". Thanks.
   / How To Shorten Comer PTO Shaft? #8
</font><font color="blue" class="small">( I believe you could use a sharp hacksaw if you could keep the cut reasonably square, but a cut-off wheel would be much easier. )</font>
I used a sawzall with a metal cutting blade, worked fine.
   / How To Shorten Comer PTO Shaft? #9
Jim, go to www.befco.com when it comes up click on technical , than adjusting the drive line,might be of some help.
Mike
   / How To Shorten Comer PTO Shaft? #10
Did exactly like Ed mentioned using a sawzall, worked great for me also.You need to make sure to get off all the burrs or it will be very difficult to slide the shafts together again.Hack saw will work fine if that is all you have available, just take a bit longer.
Good Luck,
Herb
2019 Nissan Sentra SV Sedan (A51694)
2019 Nissan Sentra...
AUCTION STARTS HERE @ 9AM (A52706)
AUCTION STARTS...
2005 Big Tex Trailer Trailer (A52377)
2005 Big Tex...
Kenmore KLFC015MWD0 Deep Freezer (A53117)
Kenmore...
2016 Mobility Ventures MV-1 Van (A51694)
2016 Mobility...
