how to setup liquid fertilizer for 4 row cultivator
   / how to setup liquid fertilizer for 4 row cultivator #1
metalman1988
two rivers wi
case 1070
I bought a 4 row cultivator with tank and ground driven squeeze pump. I dont like how it meters out and would like to replace with 12 volt pump. Does anyone have any ideas how to set up and how you meter how much you are putting down per acre. do i need to know prerssure and speed. Any help nwould be appreciated. :confused2:
   / how to setup liquid fertilizer for 4 row cultivator #2
I think you'd be better off tuning the squeeze pump.
Without modern electronics electric is not going to give you satisfactory results.
What's wrong with the squeeze pump?
   / how to setup liquid fertilizer for 4 row cultivator #3
You need to know pressure, ground speed, surface area covered, and rate of flow. Easiest way to calibrate is to hang a coffe can under the spray nozzles, start moveing the tractor at the desired speed over a measured distance, area and see how much fluid you catch in your coffecan. Once you know how much fluid you are spraying out, you can adjust flow, nozzle size or ground speed to achieve the desired application rates.
   / how to setup liquid fertilizer for 4 row cultivator #4
Metalman, can you tell us what brand the squeeze pump is? I am looking for one of these. Thank You.
2011 Nissan Rogue SUV (A50324)
2011 Nissan Rogue...
7046 (A50322)
7046 (A50322)
KJ 45'x25' Metal Garage (A50121)
KJ 45'x25' Metal...
2009 Ford Flex SE SUV (A50324)
2009 Ford Flex SE...
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
