how to sell factory rear remotes (takeoff)
   / how to sell factory rear remotes (takeoff) #1
orangetree
central idaho
kioti ck2610
Asking because I've never heard it asked & I bet it's pretty rare - I am considering removing my rear remotes from my ck10 (ck2610) for reasons; any advice on how to sell or price them? Tractor has ~200 hours, the remotes are in perfect condition & are not a low/intermittent use part anyway.
Surely you're curious - I'm adding a few circuits (top and tilt, motor directional valve, and 3rd function). It's only a few hundred more to just add 2 additional sections to the sectional valve I'm building (brand series 34), duplicating the factory remote function - and by removing/replacing the rear remotes with this I would free up the most optimal space to locate this new sectional. I am using metering manual valves - not a solendoid valve block - so I really want to add it right where the factory rr levers are. So if I could sell the RR for a decent price, it would be a wash cost wise to get a cleaner setup. If I couldn't, I'd probably jury-rig a cable based remote for the factory RR's.
I still have to confirm that it will easy for me to keep flow to the 3point (obviously factory, since the valve is in the ~transmission case), but assuming that's the case, they'd be easy to pull off cleanly. I'd sell the whole thing, as it comes in the factory kit.
   / how to sell factory rear remotes (takeoff) #2
I'm sure if you can remove everything so it's a "ready to go" kit, you should sell it very easily. Maybe check the price of it new and knock a couple hundred out of it.
Don't forget the new valve needs to have power beyond capability so it can feed the 3 pt.
Toro (A56857)
Toro (A56857)
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2000 Volvo VNL Sleeper Cab Truck, VIN # 4V4N21JF6YN250211 (A57453)
2000 Volvo VNL...
2022 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2022 Chevrolet...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
New Bolt on Receiver (A59000)
New Bolt on...
