how to sell factory rear remotes (takeoff)
   / how to sell factory rear remotes (takeoff) #1
orangetree
central idaho
kioti ck2610
Asking because I've never heard it asked & I bet it's pretty rare - I am considering removing my rear remotes from my ck10 (ck2610) for reasons; any advice on how to sell or price them? Tractor has ~200 hours, the remotes are in perfect condition & are not a low/intermittent use part anyway.
Surely you're curious - I'm adding a few circuits (top and tilt, motor directional valve, and 3rd function). It's only a few hundred more to just add 2 additional sections to the sectional valve I'm building (brand series 34), duplicating the factory remote function - and by removing/replacing the rear remotes with this I would free up the most optimal space to locate this new sectional. I am using metering manual valves - not a solendoid valve block - so I really want to add it right where the factory rr levers are. So if I could sell the RR for a decent price, it would be a wash cost wise to get a cleaner setup. If I couldn't, I'd probably jury-rig a cable based remote for the factory RR's.
I still have to confirm that it will easy for me to keep flow to the 3point (obviously factory, since the valve is in the ~transmission case), but assuming that's the case, they'd be easy to pull off cleanly. I'd sell the whole thing, as it comes in the factory kit.
   / how to sell factory rear remotes (takeoff) #2
I'm sure if you can remove everything so it's a "ready to go" kit, you should sell it very easily. Maybe check the price of it new and knock a couple hundred out of it.
Don't forget the new valve needs to have power beyond capability so it can feed the 3 pt.
Post Hole Digger (A49251)
Post Hole Digger...
2022 Club Car...
Deutz 6 Cylinder Engine (A49251)
Deutz 6 Cylinder...
2014 Dodge Ram 3500 Laramie Crew Cab Pickup Truck (A46684)
2014 Dodge Ram...
Antonio Carrago TGF9400 Orchard Tractor (A49251)
Antonio Carrago...
2015 Ford Explorer AWD SUV (A46684)
2015 Ford Explorer...
