How to rig an X595 to mow in reverse
   / How to rig an X595 to mow in reverse #101
Steve,thanks for the pic.I was so darn excitied I ran out to the barn to try this on my X740,works like a charm.Thanks again.coobie
Yeah, I was always loosing the pen caps before and now I have a place to find one when I need it.:laughing:
   / How to rig an X595 to mow in reverse #102
Wish it would rain so grass would start growing again. Anxious to try the clothespin method. :)
   / How to rig an X595 to mow in reverse #103
I think I will up end with the same problem.LOL,coobie
He said in another thread that his son takes the tractor for drives, he is allowing his son to drive it.
Allow me to elaborate, my son drives the tractor with me walking along side, never by himself, and the mower, for the most part, is removed. If you knew him you would understand. I would trust him before some of my friends.
Boy I am sure glad I found this thread.We have a lot of trees to mow around and I back up often.While I like my JD 700 series it drives me nuts to keep turning the PTO on and off.coobie
Guys its really an easy, permanent fix. Just a jumper wire on the plug behind the PTO switch. No pen caps or clothes pins needed. One of the posters posted a you tube video showing how to do it.
   / How to rig an X595 to mow in reverse #106
The only reason I chose the pen cap is my tractor is still under full factory warrenty for 3 1/2 more years.I can see it now,I take my tractor in for some type of problem and dealer saying I did something to the wireing.LOL,coobie
   / How to rig an X595 to mow in reverse #107
I suspect it depends on the dealer. When I took mine in I told them I jumpered the RIO. I asked the service manager if I needed to put it back first. He said no, and didn't blame me for jumping it out.
Now if I had got yellow for a service manager I'd have been facing the 3rd degree.
   / How to rig an X595 to mow in reverse #108
You an easier fix that is warranty proof. Wrap a zip tie around the switch so it holds it in and pull it tight. On most models the switch is against the forward pedal linkage and when the pedal is used it releases the switch and shuts the deck off. That's simple no jumper wire needed.
   / How to rig an X595 to mow in reverse #109
I'm still trying to figure out how holding a switch in the up position until you push the pedal for reverse and letting go is such a problem for people to post on for a week. That's nuts, I'm sure I sound like a real jerk, and I'm not saying Carl Bert is a bad father or nothing, I was just using that as an example. Their are jut things in life we all have to live with, this simple switch is one of them.
   / How to rig an X595 to mow in reverse #110
EASY,life is to short to get upset.coobie
2017 VOLVO VNM DAY CAB (A51222)
2017 VOLVO VNM DAY...
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A51039)
2016 Kawasaki 70...
2018 FREIGHTLINER 1085D DUMP TRUCK (A51406)
2018 FREIGHTLINER...
2021 FORD F450 TOW TRUCK (A50505)
2021 FORD F450 TOW...
2016 HINO 268 26FT BOX TRUCK (A51222)
2016 HINO 268 26FT...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
