How to replace fuel pump
   / How to replace fuel pump #1
winter5470
punta gorda, fl
lk 2552
I have kioti 2552 tractor. Recently it started leaking fuel at the fuel pump. By tightening the screws I was able to slow the drip down some. My guess is I have a bad gasket. Searching online it looks like just replacing the pump for $58 is the way to go. I did not see anybody selling just the gaskets.
My main question is how do I replace the pump without introducing air into the fuel lines. I ran it out of gas once and had to bleed the lines. I do not want to do that again!
Any help or suggestions would be appreciated.
Kurt
   / How to replace fuel pump #2
Replace the pump. Bleed the fuel lines; not a big a deal. Then check the engine oil (smell test and dip stick level) for Diesel contamination; some lift pump failures will allow fuel to get into motor oil. A tiny amount of fuel is not a big deal but enough to raise the oil level on the dip stick warrants an out-of-cycle oil change.
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
LOAD OUT INFORMATION (A53084)
LOAD OUT...
CAT Skid Steer (A50322)
CAT Skid Steer...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
THE HANDLER II MIXER UNIT (A52472)
THE HANDLER II...
