How to remove PTO shaft from slip clutch on rotary cutter?
   / How to remove PTO shaft from slip clutch on rotary cutter? #1
Soldier415
Platinum Member
Vermont
2001 Kubota L3010GST. 2005 Kubota L3430HSTC
I have a 5 ft Befco rotary cutter that came with my first tractor. Never used it and it has sat for the last 3 years. Went to hook it up and PTO shaft is pretty much rusted together. Will not compress or extend so wanted to add a new one. Was trying to get the old one off and no luck.
Removed the bolt where my finger is but no movement even after spraying down with fluid film
Even if I got it to move, it looks like there is a bevel which would prevent the shaft from being pulled off (pictured here)
Another picture of the entire setup
The manual wasn't much help as there wasn't a section covering PTO shaft removal
Any help appreciated
   / How to remove PTO shaft from slip clutch on rotary cutter? #2
That looks like a spring clip or ring, to hold the coupler on the shaft in case the bolt shears or falls out. You might have to push the coupler onto the shaft a little, then remove ring/clip, then pull shaft off.
   / How to remove PTO shaft from slip clutch on rotary cutter? #3
Pull the shaft apart & clean it up & use it.
Chain the cutter to a tree or something solid & pull with tractor or truck.
Not long enough at current stuck length to connect to tractor PTO. Guess I could connect it to a clevis on the drawbar
   / How to remove PTO shaft from slip clutch on rotary cutter? #5
Yep, that looks to me like it has a spring clip in there. You'll have to pick that out before it will budge, I think.
   / How to remove PTO shaft from slip clutch on rotary cutter? #6
This^^
Thanks. Going to let the fluid film sit overnight then take a small sledge to it to try and break it free so I can move it forward and pull out the clip
On a related note I never realized how expensive PTO shafts are. Weasler 42 in shaft is $300 at Tractor Supply
   / How to remove PTO shaft from slip clutch on rotary cutter? #9
The PTO shaft on my flail mower was seized. I tried brute force (lifting it up with the loader) - no go. Then I tried a gentler approach. I sprayed the heck out of it with PB Blaster (Rubber banded a baggie to it so it could soak). Then I chained one end to a tree, and the other end to a come a long. Did Tap, Tap Tap with a hammer, and if it flew apart.
Repeat if necessary.
2015 Chevrolet Traverse LS SUV (A56859)
2015 Chevrolet...
2012 PROCO 130 BBL VACUUM TANK TRAILER (A58214)
2012 PROCO 130 BBL...
New/Unused SD Lanch 20x20 Carport (A57454)
New/Unused SD...
2020 John Deere MX8 8' Rotary Cutter, S/N 1P00MX8HJKP045954, 540 PTO, Hydraulic Rear Wheels, Asset# (A59076)
2020 John Deere...
Informational Lot - Financing (A56435)
Informational Lot...
AUGER (A58214)
AUGER (A58214)
