Mid-Mount Mower How to remove middle blade on MF 2325
   / How to remove middle blade on MF 2325 #1
hillfarm
I can't figure how to remove the middle blade on my MMM (MF 2325). I don't have the manual and it costs $30 with shipping. Seems like it should be straightforward. I got the side blades off: two wrenches - one holding the bolt from the top and the other loosening the nut underneath. But the middle blade is connected to the gear housing. I can't remove the gear box from the spindle even after removing the bolts that secure the gear box to the mower.
So somehow I need to freeze the spindle/bolt to loosen the nut holding the blade. I've jammed a crowbar into the top, but even with a lot of torque the nut still won't budge and I'm worried I'm going to break something. Ugh. Any thoughts? Am I missing something obvious?
   / How to remove middle blade on MF 2325 #2
Use an impact wrench!! If no air find or borrow an electric.
   / How to remove middle blade on MF 2325 #3
I've always liked "liquid wrench". Spray it on the bolt and let it sit overnight. The next day rather then put a lot of torque on it, give the wrench a tap with a hammer.
2016 CATERPILLAR 239D SKID STEER (A51242)
2016 CATERPILLAR...
2013 Jeep Patriot SUV (A50324)
2013 Jeep Patriot...
DOG SHOCK COLLAR (A51243)
DOG SHOCK COLLAR...
2011 International DuraStar S/A Refer Truck (A47384)
2011 International...
Memo 98 Loader with Brackets (A50514)
Memo 98 Loader...
BUSH HOG 35-06 - 6' REAR MOUNTED BLADE SCRAPER (A51243)
BUSH HOG 35-06 -...
