Mid-Mount Mower How to remove middle blade on MF 2325
   / How to remove middle blade on MF 2325 #1
hillfarm
I can't figure how to remove the middle blade on my MMM (MF 2325). I don't have the manual and it costs $30 with shipping. Seems like it should be straightforward. I got the side blades off: two wrenches - one holding the bolt from the top and the other loosening the nut underneath. But the middle blade is connected to the gear housing. I can't remove the gear box from the spindle even after removing the bolts that secure the gear box to the mower.
So somehow I need to freeze the spindle/bolt to loosen the nut holding the blade. I've jammed a crowbar into the top, but even with a lot of torque the nut still won't budge and I'm worried I'm going to break something. Ugh. Any thoughts? Am I missing something obvious?
   / How to remove middle blade on MF 2325 #2
Use an impact wrench!! If no air find or borrow an electric.
   / How to remove middle blade on MF 2325 #3
I've always liked "liquid wrench". Spray it on the bolt and let it sit overnight. The next day rather then put a lot of torque on it, give the wrench a tap with a hammer.
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
8x18 Metal Rack Hay Wagon (A50774)
8x18 Metal Rack...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A51243)
2016 WITZCO RG-35...
Unused Rhino ER10 Hay Rake (A50515)
Unused Rhino ER10...
2022 Third Coast Reversible Plate Compactor (A51573)
2022 Third Coast...
2018 John Deere 470G Hydraulic Excavator (A50322)
2018 John Deere...
