How to remove internal filter from JD 350b hydraulic resevoir
   / How to remove internal filter from JD 350b hydraulic resevoir #1
roanmtsawdust
Johnson City, TN
JD 350B
I recently purchased a 350B dozer (serial 0807101). Yesterday the hydraulics suddenly quit working immediately after asceding a short steep hill. No leaks. I topped off fluid to no avail. The next day the hydraulic worked for a couple of minutes then quit. I suspect restricted flow to the hydraulic pump from an internal filter in the resevoir. I can feel in the resevoir and the filter appears to have a spring type retaining feature but I'm a little afraid to pull apart something I can not see well.
Has anyone disassembled this before. I plan to go get the service manual and owners manual but would appreciate any experience. thanks in advance for any help
   / How to remove internal filter from JD 350b hydraulic resevoir #3
Exploded views on JDparts.com might help too.
Thanks for the replies. Once I emptied the oil from the tank it was pretty obvious. I had heard you could remove with the oil in the tank (and they were correct). The suction filter to the hydraulic pump is held in place inside the tank with a spring and bolt assembly. Nothing fancy once you see it.
Two Post Car Lift (A50120)
Two Post Car Lift...
2013 PETERBILT 367 HOT OIL UNIT (A53843)
2013 PETERBILT 367...
2013 Ford Transit Connect Van (A52377)
2013 Ford Transit...
PALLET OF SCAFFOLDING PARTS (A52706)
PALLET OF...
UNUSED Clear Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Clear...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
