How to remove gear box Kubota RC 44 series mower decks
   / How to remove gear box Kubota RC 44 series mower decks #1
msjanket
I need to remove the deck gearbox to replace the belt on my RC44-42 mower deck. I'm assuming that I need to remove the snap ring inside the gearbox and lift the gear box off, after removing side bolts that anchor it to the deck. Does this sound correct or is there some easier way? There is insufficient room to slide the belt under the input shaft as the deck is only about a quarter inch below the shaft and the belt is about twice that in thickness.
thanks
   / How to remove gear box Kubota RC 44 series mower decks #2
Haven't seen that particular deck, but on the bigger decks, you pull the blade, then the 4 bolts that hold the gearbox on and it comes off.
Aaron Z
   / How to remove gear box Kubota RC 44 series mower decks #3
thanks
You remove the 4 bracket bolts from the right side only (looking from the back side of the gear box). The belt will slip from underneath the front of the gearbox in order to replace it.
If you want a copy of the entire manual for this deck, I uploaded it to Kubotabooks.com recently. It is in the mowers and catchers directory.
Profnohair
40ft Shipping Container (A52377)
40ft Shipping...
1/4 '' Wolverine Universal Quick Attach Mount Plate (A51573)
1/4 '' Wolverine...
2011 KOMATSU PC56-7 EXCAVATOR (A51246)
2011 KOMATSU...
434669 (A48836)
434669 (A48836)
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A53472)
3-Point Hitch Root...
