I need to remove the deck gearbox to replace the belt on my RC44-42 mower deck. I'm assuming that I need to remove the snap ring inside the gearbox and lift the gear box off, after removing side bolts that anchor it to the deck. Does this sound correct or is there some easier way? There is insufficient room to slide the belt under the input shaft as the deck is only about a quarter inch below the shaft and the belt is about twice that in thickness.
thanks
thanks
