How to remove Deere x728 ignition switch
   / How to remove Deere x728 ignition switch #1
mikefamig
CT
JD X728
Does anyone here know how to remove the ignition swtich on the Deere x728 tractor? It looks as though I may be able to pry the plastic panel that it is attached to but I am afraid of breaking it. Otherwise it looks as though I will have to remove the steering wheel and and instrument panel.
TIA, Mike.
   / How to remove Deere x728 ignition switch #2
Mike,
When you say "ignition switch" are you referring to the switch that is use to start the engine?
   / How to remove Deere x728 ignition switch #3
The X728 ign sw shows in jdparts.com as part no. TCA22740 (item 32) and this pic shows how it is held on with a ring nut (item 33). Does it look like what you are trying to remove?
Mike,
Yes the switch to start the engine
Yes that looks like the switch.
   / How to remove Deere x728 ignition switch #6
How do you know the switch is bad?
   / How to remove Deere x728 ignition switch #8
Don't know what part of removing the switch is the problem... a pic or two may help us help you figure out the next step.
If you owned an x728 you woould know what the problem is. You can not easily get to the back of the instrument panel in order to remove the switch.
   / How to remove Deere x728 ignition switch #10
OK carry on... just thought we could help you.
And yes, you do have to remove the instrument panel as described in your service tech manual.
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A51219)
2016 INTERNATIONAL...
1994 Chevy  2500 Dually Pick Up Truck (A50515)
1994 Chevy 2500...
1985 Toyota Pick Up Truck (A50515)
1985 Toyota Pick...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
(2) ROLLS OF HD CHAIN LINK MESH WIRE (A50460)
(2) ROLLS OF HD...
2014 CATERPILLAR 272D XHP WHEELED SKID STEER (A51242)
2014 CATERPILLAR...
