How to remove a LT180 rear deck
   / How to remove a LT180 rear deck #1
pmasters
Fountain Inn
Massey Ferguson 1240
I have a John Deere LT180 that I've had nothing but problems from. It got to where it didn't want to pull up a hill, which I put up with until it broke a rear axle. I had to drop the entire rear end, and get a used one to replace the broken axle. Now, it just stops and has subsequently started making a loud noise. I'm thinking that the keyway is partially sheared off and is what is making this scraping noise. I remember how hard it was to drop the rear end to replace the axle, and this man told me that you could take the rear deck off (which has the seat and everything else), and you can see down in to replace belts and other assorted parts. I've looked at it, and for the life of me, I can't figure out how to take that rear deck off, and I don't want to tear something up. I'm no mechanic, but if I have directions to follow, I can usually do it, but I cannot find directions anywhere on how to remove the rear deck.
   / How to remove a LT180 rear deck #2
Sorry to hear you are having so much trouble with it.
What a pain. Have you tried YouTube to see if someone has a video of how to remove it?
VIN: 57WMD1A60EM100447, Year: 2014 Make: Mobility Ventures Model: MV-1 Vehicle Type: Van Body Type: (A56858)
VIN...
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A59575)
2014 PETERBILT 384...
8 LUG ALUMINUM RIM FOR FORD F-250 (A58374)
8 LUG ALUMINUM RIM...
2019 Caterpillar 259D Compact Track Loader Skid Steer (A56857)
2019 Caterpillar...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
2009 Ford Crown Victoria Sedan (A56859)
2009 Ford Crown...
