How to Raise MMM?
   / How to Raise MMM? #1
strez
Southern Tier, NY
New Holland TC30 HST 4WD
OK, here goes a dumb question. How do you raise and lower a MMM (specifically, on a New Holland TC30) to adjust the cut height?
   / How to Raise MMM? #2
You may want to move this post to the NH owning and operating forum. The folks over there should be able to help you out.
DaveL
   / How to Raise MMM? #3
Strez,
Greetings from Monterrey Mexico. I am commissioning some equipment here and caught your post.
I'm not sure which MMM you are asking about, but my 914A 60" MMM (TC29D) has the height adjusted by a rear wheel assembly that is adjusted by a lever assembly with hitch pin. The front wheels also have a height adjustment by placing a pin in one of several holes in the vertical swivel shaft. Hope this helps.
   / How to Raise MMM? #4
Strez,
What model mower do you have?
   / How to Raise MMM?
I am planning on buying the MMM model 914A, rear discharge.
   / How to Raise MMM?
</font><font color="blue" class="small">( . . . has the height adjusted by a rear wheel assembly that is adjusted by a lever assembly with hitch pin. The front wheels also have a height adjustment by placing a pin in one of several holes in the vertical swivel shaft )</font>
The way I understand this is that the MMM is always riding on it's wheels, right? There is no way to 'lift' the deck so that the MMM is not touching the ground?
   / How to Raise MMM? #7
You lift the deck by raising the 3ph.
   / How to Raise MMM? #8
</font><font color="blue" class="small">( You lift the deck by raising the 3ph. )</font>
To continue further, the midmount mower can then be locked in the "up" position so you can use raise and lower the 3ph when other implements are on it.
Mark
   / How to Raise MMM? #9
The wheels are for scalping control, the weight is on the 3pt arms that raise and lower the mower.
The wheels are adjustable up and down (i keep mine 1/2" or 12mm above the concrete floor when setting mower up).
Set the 3pt stop at the mower height and go.
Like previous post raise mower all the way up and it can be pinned there and 3 pt is free to use other attachments.
I've got a 84"MMM and this is a great mowing unit.
   / How to Raise MMM? #10
Strez,
The 914A MMM is indeed carried by the 3 pt. hitch, and the wheels keep you from scapling the ground, but the 3 point hitch linkage for the MMM has a "float" setting that allows the deck to freely raise when the ground rises under the deck, that way the deck is not locked in one position.
Sterling AT (A56435)
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
Forklift Safety Basket (A56857)
Forklift Safety...
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
2020 DRAGON ESP...
2015 FORD F-350 XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-350 XL...
