How to protect a bearing from the elements
/ How to protect a bearing from the elements #1
dieselscout80
Elite Member
South Carolina
New Holland TC45DA
I have a idler pulley with bearings on my tractor IH 424 (yes it sits outside) that's not sealed. They have metal shielding.
Can can I smear silicone on a bearing to seal it from the elements?
/ How to protect a bearing from the elements #2
I'd think that would just attract a lot of grit that would help destroy the bearing. I bet that a good bearing supplier could match yours up with replacements with identical dimensions but with a rubber seal.
/ How to protect a bearing from the elements #3
from past experience the metal shield is better than rubber because the metal is designed to run in oil which is much more of a sealer than the rubber seal i am doing some work on hand crank trap kit all the bearings are metal seal because they are exposed to the elements always anybody else understand this to be true
/ How to protect a bearing from the elements #4
'80': Just cut an old plastic bottle or something to install over the idler when you're not using it - Keep the rain off it.
I take it the bearing is not 'greaseable'?
Mitch: I'm struggling with your post. You need to install some punctuation. Suffice to say, Metal Shielded bearings accept grease more readily than Rubber Seals, which keep dust and some moisture out better.
What is a hand crank trap kit ?
The idler has two National 202S bearings stacked together. I was thinking I could pop the two inner metal seals off and then drill the pulley for a grease zerk. I wonder if just greasing the bearing will keep it working for a long time. However, I also found some nylon washers that will cover the bearing.
/ How to protect a bearing from the elements #6
Grease is the 'lifeblood' of bearings.
/ How to protect a bearing from the elements #7
/ How to protect a bearing from the elements #8
"From past experience, the metal shield is better than rubber. This is because the metal shield is designed to run oil, which is much more of a sealer than it's rubber counterpart. I am doing some work on hand crank trap kit(?), all the bearings are exposed to the elements at all times. Does anybody else understand this to be true?"
Fixed?
/ How to protect a bearing from the elements #9
Fixed?
I'm not sure...
"This is because the metal shield is designed to run 《in》oil, which is much more of a sealer than it's rubber counterpart."
The "oil" is a better sealer?
Bearings running with oil present on one, or both, sides tend to be 'open' on the side where oil is present. (One or both sides). The oil is the lubricant.
/ How to protect a bearing from the elements #10
Yeah! What in the world is a (hand crank trap kit)?
/ How to protect a bearing from the elements #12
Here's my take on the matter. A shielded bearing has metal shields that ride very close to, but never touch, the inner race of the bearing. Shielded bearings are designed to keep large particles out of the bearing and are typically specified for higher speed applications >3500 rpm or thereabouts. The metal shields can be removed if needed such as in an oil filled gearbox or on a greasable electric motor. Rubber seals in high speed applications will overheat and fail, this is why you'll find shielded bearings on your Porter Cable 690 woodworking router.
Sealed bearings are designed for lower speeds <3500 rpm and have rubber lip seals that contact the inner race. Good for keeping dust and moisture out, but they aren't submersible. The rubber seals can be removed and re-installed at will or if you want to pump a little grease in there down the road.
So back to the OP question of slathering some silicone (I presume RTV silicone sealant) on the topside of the shielded bearings, I'd say no. Simply realize that just like the belt idlers on your mower deck, they will be replaced a little more often due to their inherent design and move on.
/ How to protect a bearing from the elements #13
Try using a high quality synthetic marine grease which repeals water to pack the shielded bearing with.
/ How to protect a bearing from the elements #14
About the only way to properly seal a bearing is to have a positive pressure system in place.
/ How to protect a bearing from the elements #15
okay to answer first and seems to be the most foremost question about my statement tarps systems on trucks and other equipment are e 12v electric motor driven .Small 5 yard trucks and trailers use the true hand crank to move the tarp from front to rear and back to somewhat secure the load i am doing for these for state road dept and they have about 30 of these in service now and having sold many bearings in the last 53 years the metal shield by far is better for extreme exposure not only is it oil resistant and most any element mother nature throws at it. and by the way the tarp kits i am working on are mostly only used on salt trucks. The interior of bearing requires only a very small amount of grease mostly the ones sold by chevron the rubber seals will shrink to a point they let the elements in the metal seals have very little room for shrinkage and as someone has mentioned true bearing that are run in oil all them time 1 side is exposed to the oil to keep in running cool the other side is mostly metal sealed.
/ How to protect a bearing from the elements #16
Just a note of comparison.
Automotive practice for "front of engine" ancillary elements such as water pumps, alternators, fan pulleys and belt idlers is to use SEALED bearings. One never sees shielded bearings for these applications.
RPMs can easily exceed 3500,
My choice for nearly any application is double SEALED.
Just an anecdote, and not relevant to environmental exposure, but.... In my younger days, I built a racing motorcycle with a two stroke engine. I used Double SEALED bearings on the crankshaft to better "stuff" the crank case in efforts to improve flow and breathing. The particular engine had "direct oil injection" for the crank bearings, but still required a light oil gas mix to assure lubrication to the piston skirt etc.
Sealed bearings would seem contrary to an open lube system that easily exceeded 10.000 rpm. The bearings served for several years. They even survived a top end piston failure without a hitch. Perhaps the rubber seal lips burnt away due to friction and heat, but even then, the DOUBLE SEALED bearings were no worse than SHIELDED bearings.
For me, Sealed bearings are a first choice.
/ How to protect a bearing from the elements #17
... i am doing some work on hand crank trap kit all the bearings...
TARP kits!! You wrote Trap kits!!! No wonder we were confused.:confused2:
Not saying I would have immediately known what a 'Hand Crank Tarp Kit' was ... :ashamed:
Thanks for clarfying Mitch.
/ How to protect a bearing from the elements #18
Fixed?
For this type of situation step back a few years and use greaseable wooden bushings.
/ How to protect a bearing from the elements #19
I was just "translating"- I have no opinion on bearing types or seals. ;)
And Mitch- Tarp kits, gotcha!
This idler pulley is on a diesel engine, so I doubt a wood bearing would last even one day.
AR500 Coyote Target (A65640)
AR500 Coyote...
2022 EZ-GO ELITE...
2017 Chevrolet Tahoe SUV (A64557)
2017 Chevrolet...
82" X 18' EQUIPMENT TRAILER (A64277)
82" X 18'...
2005 Lexus ES Sedan (A64194)
2005 Lexus ES...
12' x 24' Cattle Shelter (A66408)
12' x 24' Cattle...
