How to plumb dual-axis hydraulic joystick at rear of NH TC30 (no FEL)?
   / How to plumb dual-axis hydraulic joystick at rear of NH TC30 (no FEL)? #1
jack32008
Suwannee River, FL
2023 TYM T474HST w/FEL, Loaded rear tires
I have a TC30 without a FEL and need to plumb into the tractor's hydraulic system to run a dual axis joystick that will be mounted at the rear of the tractor. The joystick (Brand Hydraulic Loader Directional Control Valve LV22RFSTKAB with Joystick Regen | eBay) will be used to run a Woods TSG50 stump grinder (LT/RT cylinder and UP/DN cylinder) . Can anyone with knowledge of the TC30 hydraulic system advise where I should take power from and then where to run the return line from the joystick? NOTE: I need to keep the 3PT hydraulics working along with the joystick/stump grinder functions as I will need to lift the grinder to reposition the tractor and implement over stumps. Also, I ordered the Woods TSG50 with the 4-hose kit that connects to 2-sets of rear remotes, without a manual or electric diverter valve kit on the TSG50. I hope to turn the joystick valve into 2-rear remotes by adding quick disconnects (QDs) directly to the A1/A2/B1/B2 ports on the joystick. If anyone sees a problem with this 'plan', I would really appreciate hearing your opinion or recommendation.
Any photos or diagrams showing where to connect the OUTPUT line from the tractor and the RETURN line from a joystick to the tractor would be VERY helpful and MUCH appreciated! NH offers a single rear mounted remote kit for the TC30 which may provide insight as to where I could plump into the TC30, but I have been unable to find the kit installation instructions online.
Thanks in advance,
Jack
   / How to plumb dual-axis hydraulic joystick at rear of NH TC30 (no FEL)? #2
Aaron,
My local dealer wants $1350 to install a SINGLE remote on my TC30! I am trying to avoid that expense at all costs. Seems to me I should be able to 'tap in' to where the FEL would normally be powered from and then back to the hydraulic tank or manifold. Since I have no FEL installed on my TC30, don't you think that would be the better solution?
Thanks for your help/reply.
Jack
   / How to plumb dual-axis hydraulic joystick at rear of NH TC30 (no FEL)? #4
What you want is not a remote, what you want is the power beyond block like they would install with a backhoe. That will let you put your new valve "in line" between the pump and the 3 point. It looks like this might be the kit you want: Object moved but you may not have the block that item 5 screws into.
Give Messicks a call in the morning, tell them that you want to add Power Beyond connections to your TC30 like you would use to power a backhoe and ask what you need.
Here is a breakdown of the hydrualic system on your machine: Object moved (Section 7, Subsection 05E01) you want to tap into the high pressure line between the pump and the 3 point valve.
Aaron Z
Thanks Aaron! I'll give Messicks a call.
Jack
NEW Wolverine 72in Skid Steer Tiller (A59000)
NEW Wolverine 72in...
44052 (A55852)
44052 (A55852)
Kubota U55-4 (A57148)
2015 FORD F-350 XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-350 XL...
2014 Transcraft Trailer (A55973)
2014 Transcraft...
CATERPILLAR 80" QUICK ATTACH BUCKET (A51406)
CATERPILLAR 80"...
