How to plumb dual-axis hydraulic joystick at rear of NH TC30 (no FEL)?
   / How to plumb dual-axis hydraulic joystick at rear of NH TC30 (no FEL)? #1
jack32008
Bronze Member
Suwannee River, FL
2023 TYM T474HST w/FEL, Loaded rear tires
I have a TC30 without a FEL and need to plumb into the tractor's hydraulic system to run a dual axis joystick that will be mounted at the rear of the tractor. The joystick (Brand Hydraulic Loader Directional Control Valve LV22RFSTKAB with Joystick Regen | eBay) will be used to run a Woods TSG50 stump grinder (LT/RT cylinder and UP/DN cylinder) . Can anyone with knowledge of the TC30 hydraulic system advise where I should take power from and then where to run the return line from the joystick? NOTE: I need to keep the 3PT hydraulics working along with the joystick/stump grinder functions as I will need to lift the grinder to reposition the tractor and implement over stumps. Also, I ordered the Woods TSG50 with the 4-hose kit that connects to 2-sets of rear remotes, without a manual or electric diverter valve kit on the TSG50. I hope to turn the joystick valve into 2-rear remotes by adding quick disconnects (QDs) directly to the A1/A2/B1/B2 ports on the joystick. If anyone sees a problem with this 'plan', I would really appreciate hearing your opinion or recommendation.
Any photos or diagrams showing where to connect the OUTPUT line from the tractor and the RETURN line from a joystick to the tractor would be VERY helpful and MUCH appreciated! NH offers a single rear mounted remote kit for the TC30 which may provide insight as to where I could plump into the TC30, but I have been unable to find the kit installation instructions online.
Thanks in advance,
Jack
   / How to plumb dual-axis hydraulic joystick at rear of NH TC30 (no FEL)? #2
Aaron,
My local dealer wants $1350 to install a SINGLE remote on my TC30! I am trying to avoid that expense at all costs. Seems to me I should be able to 'tap in' to where the FEL would normally be powered from and then back to the hydraulic tank or manifold. Since I have no FEL installed on my TC30, don't you think that would be the better solution?
Thanks for your help/reply.
Jack
   / How to plumb dual-axis hydraulic joystick at rear of NH TC30 (no FEL)? #4
What you want is not a remote, what you want is the power beyond block like they would install with a backhoe. That will let you put your new valve "in line" between the pump and the 3 point. It looks like this might be the kit you want: Object moved but you may not have the block that item 5 screws into.
Give Messicks a call in the morning, tell them that you want to add Power Beyond connections to your TC30 like you would use to power a backhoe and ask what you need.
Here is a breakdown of the hydrualic system on your machine: Object moved (Section 7, Subsection 05E01) you want to tap into the high pressure line between the pump and the 3 point valve.
Aaron Z
Thanks Aaron! I'll give Messicks a call.
Jack
2003 CATERPILLAR 420D BACKHOE (A51242)
2003 CATERPILLAR...
2019 FORD F450 TOW TRUCK (A51222)
2019 FORD F450 TOW...
2019 Ford F-150 4X4 (A50397)
2019 Ford F-150...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
John Deere Gator XUV835M 4x4 Utility Cart (A48082)
John Deere Gator...
2013 John Deere 608C Corn Head (A50657)
2013 John Deere...
