Grading How to pitch or tilt my Frontier blade
   / How to pitch or tilt my Frontier blade #1
RalphVa
Super Member
Charlottesville, VA, USA
JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
I got my Frontier rear blade this morning. Was looking through the owner's manual and couldn't find a diagram that shows how to pitch the blade at the 15 or 30 degree angles they say it's capable of. Sent a note to the saleman.
Anyone have a diagram or can easily explain it?
Oh, also: has anyone put a cow mat on in place of the replacable blade on the Frontier? Figure to use it for snow plowing (backwards) and would like to put a squeegee-like gizmo on there to keep from gouging my new driveway. Read where folks have used cow mats from TSC.
Spent more time connecting the MacKissic shredder/chipper and checking the PTO drive length, etc. after connecting and dumping the blade.
Alas, I was starting to get some bronchitis or flu-like symptoms after the delivery. So, I crashed this afternoon and didn't use my toys. Had stolen 2 truckloads of leaves from town to shred up, too, and had some other stuff already piled up.
Ralph
   / How to pitch or tilt my Frontier blade #2
In which plane do you want to pitch? The right to left pitch is with the adjustable lift arm connecting link to the rocker arm, I believe. The rotation is at the center pin, and the edge of the blade is adjusted with the top link. I think that takes care of all the 'degrees of freedom' that you have other than the height of the blade.
   / How to pitch or tilt my Frontier blade #3
I used a horse stall mat from TSC, and a bailer belt for a snow guide on the top of my LandPride blade. I'll try to post some pics this weekend.
   / How to pitch or tilt my Frontier blade #4
</font><font color="blue" class="small">( Oh, also: has anyone put a cow mat on in place of the replacable blade on the Frontier? Figure to use it for snow plowing (backwards) and would like to put a squeegee-like gizmo on there to keep from gouging my new driveway. Read where folks have used cow mats from TSC.
)</font> <font color="brown"> </font>
A piece of pipe, attached to the Bottom edge, also works.
Hadn't thought about the 3 pt leveling adjustment. They should say this in the owner's manual.
Found an old thread where they talked about a horse mat (4x6x3/4" @ TSC & ~ $40). Most sandwiched it between the replaceable edge and the blade, with overlap to form the rubber edge at the bottom.
Was thinking about a piece of radiator hose for the edge of my FEL. Could do the same for the Frontier. Not sure how many sweeps it'll last.
Ralph
2016 Freightliner Derrick Digger Truck (A55973)
2016 Freightliner...
2012 CHEVROLET SILVERADO 1500 (A58214)
2012 CHEVROLET...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2021 Cat 259D3 (A53317)
2021 Cat 259D3...
BUYERS PREMIUM & PAYMENT TERMS (A57880)
BUYERS PREMIUM &...
New Holland 1412 Discbine Pull Type Mower Conditioner / Windrower (A56435)
New Holland 1412...
