Mowing How to mow a slope with a tractor?
   / How to mow a slope with a tractor? #31
My dad used to mow sideways on some very steep hills, would make me cringe.
   / How to mow a slope with a tractor? #32
Over the years, we've had the best results backing up steep hills while mowing. On the way down, angle slightly toward the next uncut area and repeat. It works good and there's no other way I would feel comfortable mowing the real steep stuff.
PS- wear your seat-belt and keep the bucket low. 4WD is a must.
x2...go extremely slow and only after walking the area to determine if there are any rocks or holes that may pose a sudden shift in balance with unsavory results.
   / How to mow a slope with a tractor? #33
AND, one other thing; if you have a ROPS, use it! It could save your life.
   / How to mow a slope with a tractor? #34
So I am one of the few people in the forum with a machine designed for working on slopes. Lots of solid advice here so far, but a few pointers on my end.
Tire pressure is one of the keys to all of this. I run at 4PSI with 4 ply tires on the steepest slopes (45 degree sideways is my rating). I see the road crews mowing and to this day I do not see how they do it. I am on a machine designed for slope work and my pucker meter screams at 30 degrees, let alone 45. Trust the pucker. It is natures way of telling you you are in trouble. Trust it.
Finally, when I talk to people about slope mowing I find that most of the accidents / incidents don't happen when mowing but when panicking cause you have gone to far. Maybe its the same but it seems like the accidents happen after the person has realized they have exceeded the limit and are trying to get themselves out of trouble.
Mow in the evening. Dry grass is the only good grass when it comes to slopes.
Finally, have an exit at the bottom of the hill. Nothing I hate more than loosing control (and even I do, but rollovers are not a concern really) and finding myself at the bottom of a ravine without an exit plan. It involves then Dozers, winches, cursing and embarrassment.
Oh, here is an old ad that was used for comparison work
Power Trac 185 vs. Kut Kwick Slopemaster - YouTube
   / How to mow a slope with a tractor? #35
Different strokes for different folks. IMO the weight of the bucket reduces rear wheel traction (aka no brakes). That's never a good thing on a slope. Learned that lesson the hard way, on a runaway tractor that nearly rolled over. It's an OH CHIT moment when the brakes are applied and nothing happens.
4WD helps both braking and traction. My FEL does not make my back tires lose traction unless I have a full bucket and no ballast. I seldom use brakes with HST and 4WD. If I was mowing and needed more traction, I would raise mower enough to have that weight.
   / How to mow a slope with a tractor? #36
I would add my machine ahs a Float Mode. Flip the switch and it puts a bit of floating up pressure on the arms, creating additional down weight from whatever implement is in the front.
   / How to mow a slope with a tractor? #38
What about backing up the hill while mowing?
That's the technique I have used with success for years. If the wheels start spinning, that's God's way of telling you the slope is too steep.
   / How to mow a slope with a tractor? #39
A guy was killed on a county gravel road that goes across our property when he, so we think, clutched his old Ford tractor going downhill, let it get some speed, then let out on the clutch and the tires skidded turning him sideways and turning the tractor over on him. A cousin's nurse wife heard the crash and tried to save him but he died as she was trying to breath for him.
NEVER clutch when on a slope unless you are barely moving and have your feet on the brakes. The tractor can gain speed seemingly instantly and you are in bad trouble. Use the throttle to slow down or hit the brakes with the clutch engaged. Another reason I like HST even though it can cause another set of problems.
I mow a pretty steep hillside every year on that same farm farm in the Clarks River bottom. I have mowed those slopes for more than forty years and have scared myself sh----ss several times.
At the top of the hill is the narrow paved road that goes thru the farm. I always drive uphill on the shallower slope drive a short distance on the road and mow downhill. Backing up a hill can cause you to loose traction and with the 2wd tractor I use that in itself can increase the pucker factor greatly.
One thing not mentioned here. If you are mowing even slightly across a slope always have your brakes unlocked and your foot on the downhill side brake. This saved me when I was a teen and chiseling on a 1206 International (a large tractor with NO rollbar). For some reason I jerked the chisels out of the ground while traveling at a good speed on a side slope. The right tire came off the ground and the tractor tried to go over to the left. I stomped the left brake. The tractor pivoted to the left and the right tire came down hard. It nearly threw me off the tractor and I continues down hill. Took me a few minutes to get my nerve back but I left the chisel in the ground on the next pass.
Whatever you do stop and look at the hill before you mow. Plan out what you are going to do BEFORE you commit.
RSKY
Thanks for all the advice. I mowed it with the tractor this weekend. Was able to go and up an down in forward, very slow, with four wheel drive. Never felt unstable or out of control. An obvious key worth mentioning is no shifting on the slopes, and no riding down with the clutch pedal pushed down. The engine braking was nice.
2012 Freightliner Bucket Truck (A55973)
2012 Freightliner...
2019 GENIE S-45 BOOM LIFT (A52709)
2019 GENIE S-45...
2014 Chevrolet Silverado 1500 (A55973)
2014 Chevrolet...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A55315)
2023 Kubota...
2021 Cat 259D3 (A53317)
2021 Cat 259D3...
2011 Chevrolet Traverse 1LT SUV (A55758)
2011 Chevrolet...
