TractorGuy
Elite Member
- Joined
- Sep 15, 2013
- Messages
- 4,611
- Location
- N. FL
- Tractor
- John Deere 4310 CUT, Ford New Holland 575E Industrial Backhoe, John Deere F725 Front Mount Mower
I used your cylinders in my rebuild of an old John Deere loader. It has worked out okay for a fraction of the cost of OEM.
One thing it does every time I start the tractor and raise the loader is the loader judders like something is binding. After a few cycles it works smooth. It has done it from the very first cycle so I think it is in the cylinder pistons. All the loader pins were greased on assembly and slid in smoothly when they were installed. They have been routinely greased so I don't suspect any of them are the cause.
Other than that the loader operates okay and has increased travel and lifting capacity over the original 420 cylinders.
https://www.tractorbynet.com/forums.../407714-aftermarket-cylinders-420-loader.html
