how to make bucket cutting edge flat again
/ how to make bucket cutting edge flat again #1
johann
bx2200
I have noticed that my FEL bucket is bent on the cutting edge, the center touches the ground before the sides. It is a gradual bend, about 3/4 of an inch deflection, I tried to pull it straight by hooking a come along to the top of the bucket and ratcheting it into deflection the opposite way, when I relieved the pressure it just sprung back to where it was. Any one got any ideas on how I can get it flat again? I got my machine used, I don't know if it was like that when I got it, I assume that it is supposed to be flat.
/ how to make bucket cutting edge flat again #2
Add a little heat and it may stay in the position you have bent it too.
Best is to get a new much heavier cutting edge and weld it on. That would make a world of difference.:D
/ how to make bucket cutting edge flat again #3
I have an 8" cutting edge from a skid steer bolted to my bucket. My dealer installed it 10+ years ago. 600+ hours later the edge still looks new and the bucket is straight. Another 30 years and I might need to flip that cutting edge. I'll be glad then that it's bolted on, instead of welded.
/ how to make bucket cutting edge flat again #4
You will need a weed burner propane blow torch to get enuf heat to matter. You need a lot of force too. Be care to not bend the top of your bucket. Probably best to just leave it alone - or get the thicker edge as Egon said. The stock ones almost all get that way when you use them firmly ...
larry
/ how to make bucket cutting edge flat again #5
They cut off quite easily. Just requires a fellow that knows how to use a torch. When the cutting edge was cut off my Kubota there was just a nice straight edge after the cutting.:D:D
I am planning on sharing a tooth bar with a friend so I don't think that I can go thicker with the cutting edge, I will have to try the heat thing. mabe cut the edge off and flip that and re-weld it on? I guess this is not that uncommon a problem......
/ how to make bucket cutting edge flat again #7
If you don't have the tools to do this at home a good welding shop should be able to fix you up. This is beyone the ability of most dealers.
Dan
/ how to make bucket cutting edge flat again #8
If you can chain each end to a piece of steel, I used a trailer frame, then use a hydraulic jack in the middle you can get more force than with a comealong and not have to worry about bending the top of the bucket down. Just be aware things can shoot out.
/ how to make bucket cutting edge flat again #9
I just straightened mine last weekend. I took the bucket off, flipped it over and blocked it so the cutting edge was level, then used chain hooks and chains to secure the ends of a beam (made of (2) 2x8's on edge with another 2x6 flat on the bottom) at either end of the bucket and used a hydraulic bottle jack in the middle to press the cutting edge back into shape. I had to go quite a bit beyond straight in order to allow for spring-back. Take it in small steps, relieving the pressure and checking to see how much more it needs to go rather than trying to do it in one shot.
I am liking that bottle jack idea. I have not done any torching and cutting yet, so I can still try that first. Thanks guys!
/ how to make bucket cutting edge flat again #11
I've used a bottle jack as well...I had an old PT 6" x 6" lying around and used it to spread out the force and keep it off the bucket. Used a chainsaw to cut a couple of vertical slits in the wood that would correspond to the side wings of the bucket. Put it in place, chained it down tightly and placed the jack between the cutting edge and the 6" x 6"...took my time and several tries at it, but it worked great and didn't tear anything up.
