How to make a tractor pay for itself?
   / How to make a tractor pay for itself? #1
okfarris
Okc ok
jd
Looking at buying a 50 or 60 hp tractor with cab. I spent too many days as a kid on a open air tractor in the dust. I really don't need a tractor that much, but I do need it for mowing a couple of commercial acres and I can use the FEL and box blade when building some buildings. I usually build a new building once every 18 months.
I would would be interested in finding a way to make the tractor pay for itself. I have time to mow, but I have found that most of the "commercial" brush hog mowers are using 35 hp tractors and charge about $40 an hour and to be honest, I don't think they can make the tractor pay for itself at that rate.
What are other things that can be done and the going rate for the services?
   / How to make a tractor pay for itself? #2
Just curious...if you "really don't need a tractor that much"...why are you considering such a large one?
   / How to make a tractor pay for itself? #4
And if he is building a new building every 18 mos..why even mess with a tractor...hire it done...for that little bit.
Unless he is building it for a customer and is looking for the tractor to do sitework...
Aaron Z
   / How to make a tractor pay for itself? #5
Geesh.
Welcome to TBN okfarris, btw.
He even put his question in the correct sub forum and you guys still haven't cut him any slack.
   / How to make a tractor pay for itself? #6
If you mow for 2,000 hours a year at $40/hour it should pay for itself in a few years if you accept minimum wage for yourself.
But if YOU want $50/hr for your time it ain't going to happen at $40/hr.
   / How to make a tractor pay for itself? #7
From a newbie perspective lease it out for jobs but let someone else use it. Say 125 a day? On 180 days use you pull some 22k. But after warranty put extended warranty insurance. Put a remote GPS box on. And rent it ? Just a thought. It is an interesting post. Let us know how you fare? Thanks. CG
   / How to make a tractor pay for itself? #8
Aaron Z
Yep, maybe that's what he's doing...still with that much construction going on it seems his time would be better spent on the big investment or pay day...the buildings....but what do I know ?
   / How to make a tractor pay for itself? #9
The fine folks in the Ag. Econ. Department at Oklahoma State conduct periodic surveys to determine custom rates paid/received. The most recent survey results are here: http://oces.okstate.edu/kay/ag/CustomRates%202011-2012.pdf.
This will give you an idea of the services performed/hired by farmers. Most of the activities involve field operations with implements that require more horsepower than that provided by a utility tractor.
BTW, other studies indicate that custom rates often do not cover the total cost (operating and ownership) of providing machinery services.
Steve
   / How to make a tractor pay for itself? #10
It's not going to pay for itself unless you jump through some of the hoops mentioned above. It's a piece of mind issue and mental health issue and what price can be put on that? If the wife needs a new pair of shoes, she just buys them and doesn't attempt to rationalize it.
Buy the tractor, call it good and maybe think of buying attachments for it.
2018 Ford F-250 4x4 Crew Cab Gooseneck Flatbed Truck (A51691)
2018 Ford F-250...
6 ft. Rotary Cutter (A53117)
6 ft. Rotary...
2005 Ford E-450 Super Duty Ambulance (A51692)
2005 Ford E-450...
2007 Ford F-550 Crew Cab 11FT Flatbed Truck (A51691)
2007 Ford F-550...
2018 MACK PINNACLE (A53843)
2018 MACK PINNACLE...
2016 Mobility Ventures MV-1 Van (A51694)
2016 Mobility...
