How to kill MOLES!
/ How to kill MOLES! #2
Seems to be a common problem, with no known good solution.
/ How to kill MOLES! #3
I think a doctor can just remove moles. Have you talked to your local doctor. :)
It would be pretty funny to ask about mole removal and when he asks to see the moles...surprise!
More seriously, there are some existing threads on the topic:
/ How to kill MOLES! #4
I use this style of trap. You step them into the ground and then the jaws clamp shut on the mole when they trip the trigger. The trick is you have to learn where the runs are they use all the time. It’s kind of hard to describe how exactly but I’ve learned to identify active runs. A picture of the trap and one where I got a mole.
/ How to kill MOLES! #6
I agree with Dave above. I use an older style piercing model of trap and have been very successful with them. I set as many as 12 traps at a time if necessary.
Cheers,
Mike
/ How to kill MOLES! #7
The easiest way to find active runs is to get a bundle of marker flags from home depot or similar, then go through your property and use your heel to smash down a divot in the tunnel. Then mark the side of it with a flag. Repeat. Wait 24 hours and check the divots. Divots that pop up are active tunnels. Trap the spot where the divot was popped up.
Don't bother trying to trap mounds. Only tunnels. Mounds are where moles push dirt UP out of the tunnels to make room in the tunnels. Mole traps work on the principle of straddling the tunnels so if the mole comes from either direction through the trap, it will push soil UP into the trap trigger pan and catch the mole coming from the right or left of the trap.
If you place it on a mound, it will trigger from below, not from a mole coming from either side, and will miss the mole.
/ How to kill MOLES! #9
I have pocket gophers. I can testify - granular gopher poison does not work well. This has been an exceptionally bad year for pocket gophers. Many of my lawns are almost totally dug up.
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
JOHN DEERE 5075M TRACTOR (A63291)
JOHN DEERE 5075M...
Challenger MT 700 Series Service Manuals Vol. 1 and Vol. 2 (A63117)
Challenger MT 700...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
Rightline LP5C-C5B0-A 42in Hydraulic Side Shift Forks and Frame Forklift Attachment (A61572)
Rightline...
PT 5'x8' Welding Utility Trailer (A64119)
PT 5'x8' Welding...
