3-Point Hitch How to Jack up Rear End L3010
   / How to Jack up Rear End L3010 #11
do not try to lift both wheels at the same time.
..near the wheel ...(I went and looked at my L3430 and would put the jack under the bracket that holds the 3 point hitch arm, there isn't much room and it is a thin so you need to be centered and careful that it will not slip off).
don't jack it too high, it is easier to handle if it just clears the ground and have a secondary means of support so it cannot slip or fall over, the bottle jack alone isn't sufficient for safety. (like cribbing of 4X4 blocks of wood under a part that will support the weight)
If I were to put it on the square of the axle I would put a block of wood (that would not split or shatter) to spread the weight.
there are a lot of what if's and that is why people don't say jack here with this and you will be ok. ...it is like trying to write common sense procedures, leave out one step or not put all the other possible scenarios in and some one gets hurt and sues you.
Thanks for all the advice. Fortunately I am doing this on a slab and not in the field, in the mud.
   / How to Jack up Rear End L3010 #13
If you can weld, make 2 T shape post then turn the top down. Get 2 U shape about 2 or 3" long weld on top. The T well be 2 or 3" taller then your loader frame and welded to the other upside down T . The 2 T's should be hooked together at the bottom. It is the same width as your loader frame with kickers holding the upside down stright.
Then with the loader, lift the front up high, slide the frame work you just made under the loader frame, let the front down until the rears come off the ground. Now you should have all 4 tires of the ground. No Jack and safe.
2020 BOBCAT E32 EXCAVATOR (A52707)
2020 BOBCAT E32...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
2013 VOLVO VNL (A55745)
2013 VOLVO VNL...
QUICK ATTACH SKID STEER HITCH (A57193)
QUICK ATTACH SKID...
UNUSED SDLANCH HYD MINI THUMB CLAP7P (A57193)
UNUSED SDLANCH HYD...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
