How to install new tire on wide rim.
   / How to install new tire on wide rim. #21
I have had luck using small bike tubes to fill the space... Find one that is a good fit,
soap it up, and try blowing up the tire... Once the tire gets to the bead area, it should force out the smaller
bike tube..
That's interesting. I just used some new innertubes to get my tubeless ATV Vampire tires to seat. But I
put the tube inside the wheel and tire with the stem sticking out the stem hole. Pumped it up, popped
the tube, pushed the stem into the wheel, then applied a tubeless stem from the outside.
I did not expect the tube to pop, but it did so with THREE different tubes from the same vendor, new.
Admittedly, I used 3x10 tubes inside a much wider 10" wheel/tire. I expected the tube not to blow
unless I exceeded maybe 4x normal inflated size.
Anyway, I could not do this for highway tires, but inside a tractor or ATV wheel, no problem. Leaving
a deflated tube inside a tubeless tire, that is.
This tire was way beyond mounting with straps, etc, and I already have a way to get air in there pretty
fast.
2023 54' Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54' Hooklift...
2018 Ford Fusion Hybird Sedan (A55758)
2018 Ford Fusion...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A54814)
2012 Crane Carrier...
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A52472)
2012 TROXELL...
UNUSED SWICT 66" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 66"...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55301)
GALAXY - SET OF...
