Snow Equipment Owning/Operating How to improve steering a JD316 Garden Tractor with snow blower attachment up front?
   / How to improve steering a JD316 Garden Tractor with snow blower attachment up front? #1
orangebruce
Western Wisconsin
Kubota L3430 HST, LA723 loader
I have a JD316, it is rear wheel drive with rear wheel weights, rear weights on a rack, and chains on rear wheels.
Steering is troublesome with the snow blower that has a mind of its own. What do you suggest? I need all the weight on the rear for traction.
Chains on the front tires? If so that seems to interfere with turning what kind?
Thanks, Bruce
   / How to improve steering a JD316 Garden Tractor with snow blower attachment up front? #2
Bolt some front wheel weights on the front wheels. I just lift the snowblower slightly on my Gravely rider if I have trouble with steering when blowing.
That is a good idea.
I should add it is operating on a hilly gravel driveway in the woods. To keep gravel out of blower I let a base of slippery packed snow/ice build up. So even lifting the blower up slightly or weights may not work.
   / How to improve steering a JD316 Garden Tractor with snow blower attachment up front? #4
I've got a BX25 with a 50" blower, without loaded tires but with chains on turfs. I had a 400 lb ballast box the first yr. and found that the box made my front end light and I had trouble steering in the float position, and even with the blower up a little. So I emptied the box of weight which helped a lot and this year I didn't even put it on and that worked great. I thought I needed all that weight on the rear to have traction but it turned out to be not necessary. I have a couple of little hills but the chains took care of them.
I'm in agreement with hawkeye; in your case I would add weight to the front wheels.
Dean
   / How to improve steering a JD316 Garden Tractor with snow blower attachment up front? #5
2WD & Snow blower always is a hard combination to make turn in snow and ice especially with out individual brakes. I have had to back up and turn then start blowing again. Like Hawkeye said, slightly lifting the blower Vs in float will also put weight on the front wheels to aide in turning.
2025 GPS Trailers (A56858)
2025 GPS Trailers...
2025 GPS Trailer (A56859)
2025 GPS Trailer...
2006 Tusk 500 PG-16 Forklift  3-Stage 188in Lift with Aux Hydraulics (A56435)
2006 Tusk 500...
2006 Ford F-250 Service Truck (A56858)
2006 Ford F-250...
2021 Caterpillar 308 Midi Excavator (A55973)
2021 Caterpillar...
2019 MACK GRANITE (A58214)
2019 MACK GRANITE...
