How to identify all this green stuff
/ How to identify all this green stuff #21
It's hard to guess from your description, but maybe these pictures will help. The traditional three-leaf pattern of the plant at the top identifies it as poison oak or poison ivy ( one grows like a small bush and the other is a vine). The lower photo is harmless (to people) Virginia Creeper which also likes to climb on trees and can actually choke trees to death. Hope this helps.
JimI
JimI<P ID="edit"><FONT SIZE=-1>Edited by jinman on 08/06/01 05:29 PM (server time).</FONT></P>
/ How to identify all this green stuff #22
People used to kill poison ivy by spraying it with diesel. In my opinion, that's certainly no worse on the environment than Roundup. I'm one of those lucky folks who is not allergic to it, so I just weed-eat it. I've never had a single itch, but I DON'T RECOMMEND THIS unless you are absolutely sure you are not allergic.
JimI
/ How to identify all this green stuff #23
Bird,
We don't burn our brush. We pile it in the utility trailer and take it off to a "Free" composting area near our land. They chip all the stuff into very large piles, which seem to just sit there for years.
We have TONS of Poison Ivy. Since we took back the field the stuff is now growing right out of the grass. There doesn’t seem to be a perfect way to dispose of the stuff since the oil can remain active for years (see article below).
We will eventually run out of brush runs after clearing the land and then I am going after all the Poison Ivy vines growing across the ground and the dead stuff in the trees. I plan on digging a hole, inserting PI, spray with roundup and fill hole after a week or two. I just have to remember not to scratch my nose with my gloves on!
We also had a stand of white birch trees that were covered with PI. The trees had bent 180o and the tops were touching the ground. After we cut them down, I pulled all the vines off before Paul cut them up with the chainsaw. They pull off pretty easy.
I am thinking about buying stock in Round-up. My hand was getting tired from the spray (gallon jug) so I went out and purchased a pump sprayer and the concentrated mix-your-own Round up. I can now spray 2 gallons in under 5 minutes.
I don't expect to ever be able to get rid of it along the fence line (thanks to the birds) but I hope to be able to kill it around the trees and in the field. I can always regrow the grass later! I have a feeling it will be a never ending project!
Michele
Here's a little light reading on the subject:
A couple of weeks ago, Sharon Barnes asked a question on this listserv
> about the fate of poison ivy during composting. I found the question
> intriquing so I decided to use it for the BioCycle Q&A column. Below is
> the "awaiting-final-edits" version of the Q&A column. It will be in the
> May issue. Thanks to eveyone who replied to Sharon for the information
> and leads.
> In the end I did not find much definitive information. One of the more
> interesting references was a paper from the Journal of Investigative
> Dermatology Volume 4 (1941) by B. Shelmire. Shelmire ponded, dried,
> crushed, washed, drowned and "roofed" pieces of the plant and still
> found it a potent source of urushiol even after a year and a half (to
> sensitive individuals). Unfortunately more recent data seems scarce. I
> would appreciate learning of other studies if anyone knows of them. By
> the way, the USDA Poisonous Plants lab in Logan Utah does not have much
> information on poison ivy (they are mainly concerned with plants
> poisonous to grazing animals) but they were a good place to start. --
> Bob Rynk
> Q. What is the fate of poison ivy in a composting system? The owners of
> a large pile of brush have asked to burn the pile. They say composting
> will not destroy the oils in the plant. Will burning pose even a greater
> threat through airborne contamination? (This question was originally
> submitted to the U.S. Composting Council’s Internet Listserv in April)
> A. While there is a great deal of information available about the poison
> ivy plant, and the rash that it causes, there is little guidance
> available about how to dispose of it. Fact sheets, books, and web pages
> caution us not to touch poison ivy, and not to burn it, but they stop
> short of recommending how to dispose of poison ivy vegetation. Burning
> poison ivy is a bad idea. People have developed severe reactions from
> breathing in smoke particles from burning vines. Burying poison ivy in
> the ground and putting it in the trash have been suggested as disposal
> methods but these alternatives have obvious disadvantages, especially if
> poison ivy is mixed with large quantities of yard trimmings. Apparently,
> there isn’t a good method, or at least a certain method of safely
> disposing of poison ivy.
> Intuitively, some poison ivy experts and composting practitioners guess
> that the poison ivy toxin decomposes during composting but there are
> plenty of “ifs” and “maybes” in their statements. Outside of the compost
> pile, there is ample evidence that the poison ivy toxin can persist and
> remain potent for years. Unfortunately, there isn’t a clear cut answer
> about the fate of poison ivy during composting. Here is what we do know.
> The rash that occurs from poison ivy, poison oak and poison sumac is
> caused by a family of organic compounds called urushiol (pronounced oo
> roo-shee-ohl , or you-ROO-she-ol, depending whether you read it in the
> north or south). Urushiol includes several organic molecules with an
> aromatic structure, categorized as catechols. The literature on poison
> ivy also refers to the toxin as an oil or oleoresin but urushiol is the
> more specific term used to identify the oily toxin in the sap.
> The urushiol-carrying sap is present in the roots, stems, leaves and
> fruit (but not in the pollen). The roots, in particular, contain high
> concentrations of urushiol. The sap is released when the plant is
> damaged by bruising, cutting, mowing, scraping, wind, or insects. One
> also can contact urushiol indirectly after the sap gets on clothing,
> shoes, tools, pets, and bark and firewood previously covered with poison
> ivy. Urushiol is not volatile but shredding, mowing, or burning the
> plants can create airborne particles that increases the chance of
> exposure. The plant is most potent in the spring and early summer when
> the sap is rising and the urushiol content is high. The dreaded sap is
> less abundant in the winter but still present and potent in the roots,
> stems, vines and twigs of the plant. Therefore, if yard trimmings
> contain poison ivy (or poison oak or sumac) residue, there are urushiols
> about.
> Urushiol is a stubborn substance. It has been shown to remain potent
> on dead plants, clothing and contaminated objects for years (bad news
> for everyone). In one study, plants stored in dry conditions and in
> submerged water for 17 months were less potent but stilled caused a rash
> in sensitive individuals. However, these are not the biologically-rich
> conditions of a compost pile. Because urushiol is organic, it is
> subject to biological degradation (good news for composters). One
> reference even suggests that under hot humid conditions, urushiol
> becomes inert in about a week (more good news for composters).
> Unfortunately, the research basis for this statement is not identified.
> Still, there are other indications that urushiol decomposes naturally.
> First, we are not overrun with cases of poison ivy despite the
> persistence of the toxin and ubiquity of the plants. Secondly, according
> to Susan Carol Hauser, author of Nature’s Revenge(1), leaves that
> naturally fall off the plant do not contain urushiol. Furthermore,
> leaves do gradually lose potency over time. Finally, there is anecdotal
> testimony. For instance, commenting to the U.S. Composting Council
> Internet listserv, the manager of a large yard trimmings facility
> mentioned that users of raw shredded yard trimmings mulch have reported
> developing the poison ivy rash while no users of the composted product
> have (users were cautioned about the poison ivy risk with accompanying
> written instructions).
> Large-scale composting could be a rational approach for disposing of
> poison ivy-laden yard trimmings, given the lack of good alternatives and
> the fact that urushiol is thought to decompose under conditions typical
> to composting. However, without more scientific evidence, it remains a
> risky venture. In any case, it deserves due caution and common sense in
> handling the raw feedstocks and the products. To adequately decompose,
> the urushiol must be exposed. Because poison oak, sumac, and even poison
> ivy are woody plants with fairly thick stems, the plant material needs
> to be shredded prior to composting. However, shredding also releases the
> sap, spreading it among the shredded material and possibly into the air
> near the shredder. This raises concerns about using uncomposted mulch
> made from the shredded yard trimmings containing poison ivy. As a side
> note, given the uncertainties, it is wise to keep poison ivy vegetation
> out of the backyard compost pile.
> (1) Additional sources of information: 1. Nature’s Revenge, The Secrets
> of Poison Ivy, Poison Oak, Poison Sumac and Their Remedies, Susan Carol
> Hauser, Lyons & Buford Publishers; 2. Poison Ivy, Western Poison Oak and
> Poison Sumac Agriculture and Agri-Food Canada website:
> http://res.agr.ca/brd/poisivy.html; 3. Outsmarting Poison Ivy and Its
> Cousins, by Isadora Stehlin, U.S. Food and Drug Administration website:
> http://www.fda.gov/fdac/features/796_ivy.html; 4. Poison Ivy, Oak &
> Sumac Information Center website : http://poisonivy.aesir.com/.
/ How to identify all this green stuff #24
OK, if you take it to a shredder/compost place, the article says <font color=blue>Urushiol is not volatile but shredding, mowing, or burning the plants can create airborne particles that increases the chance of exposure.</font color=blue> I've dealt with poison ivy all my life, was immune until the age of 11 or 12, and I suppose I've read just about everything I could find about it, and I fail to see how shredding it into a compost pile is any safer than burning it. In my case, my options with brush are limited to burning, digging a hole big enough to bury it, or running it through a little chipper/shredder. So, after 50 years experience, I reckon I'll just keep on burning it, but of course, the burning is done far from anyone's house and I do stay out of the smoke.
Bird
/ How to identify all this green stuff #25
Same here Bird, out in the country we just pile it up along with any other type of wood etc and try not to touch it and burn it however,I would not purposely roast hotdogs on it if I were allergic to it.
/ How to identify all this green stuff #26
I tipically don't burn it.Usually we bag it(any IVY) and put it out with the trash pick up...Though I can imagine what that oil could do to your lungs.....But when we do burn it we always burn it as far away from critters and folks as possible.When I mentioned burning I figured most folks have the good sence not to breath smoke from any type of trash,brush or de-bree. I'm sure theres a joke in this some were But It's past bed time for us night owls...
Laziness is the Father of invention.../w3tcompact/icons/laugh.gif
Lil' Paul
Proud owner of TC21D
/ How to identify all this green stuff #27
Tom,
Out here in California, we have an organization called "CNPS" (California Native Plant Society). Although not specific to your area, their web site has a lot of information about "sister organizations" in other states. You can get a lot of information from them and the other organizations.
My wife is heavily involved in native habitat issues. In fact, as I type this, she is in Yosemite Valley doing restoration work, specifically removing invasive non-native plants (making a specific distinction from weeds, or plain old non-natives). Her web site has a lot of links to organizations similar to CNPS and her own (Native Habitats).
The GlueGuy
Jim - excellent call, these are indeed the two critters. And I obviously did something stupid in a past life. It's the poison ivy climbing the wall near the front door. All the rest of the yard is *covered* with Virginia creeper.
Tom K
Bird, I tend to agree with you. The local landfill doesn't want yard waste, and the site you can take it to shreds it for use as both compost and mulch. I wouldn't want to have someone spread a wood-chip walk and then walk on it barefoot with shredded poison ivy in it.
The only other two ways I know of to get rid of it are by burning, or by running it through a goat. I'm kinda short of goats at the moment, as my neighbor got rid of hers. She couldn't keep them out of the poison ivy, and, as she says, "NEVER drink the milk from a goat that's been eating poison ivy!"
OTOH, my burn pile is currently too close to the house and too green to get a high heat fast, so I think the two wheelbarrow loads of mixed creeper and ivy are going to find their way into trash bags with some ballast and go to mummify in the landfill.
Tom K
/ How to identify all this green stuff #30
Talk about sour milk!!!!!/w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gifBet that was a taste bud nightmare!!!
Lil' Paul
/ How to identify all this green stuff #31
Glad to help, Tom. My oak woods (forest) floor is covered with poison oak in the late spring. I was shopping a few years back and the plant shown on a shirt caught my eye. You guessed it...the print was poison oak leaves. Sometimes when I wear that shirt I ask folks to identify the leaves. Over 90% of the time they cannot do it. After seeing a picture, it's a lot easier to spot in the woods or anywhere else./w3tcompact/icons/cool.gif
JimI
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A64280)
2001...
40' High cube 6 door Single use Shipping Container (A64194)
40' High cube 6...
2020 Toro Groundsmaster 7200 72in. Zero Turn Commercial Mower (A64553)
2020 Toro...
2018 Chevrolet Tahoe SUV (A64557)
2018 Chevrolet...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2011 GMC Acadia SUV (A64557)
2011 GMC Acadia...
